Jingle Bells...
by GumbyJarvis - 12/12/19 02:38 PM
Meguiar's M305
by sohccammer427 - 12/12/19 02:29 PM
Will it fit?
by Bettez88 - 12/12/19 12:58 PM
Diagnosis Confirmatioin
by Gebo - 12/12/19 12:58 PM
Mercury 25hp PCMO
by SimpleGuy48 - 12/12/19 12:50 PM
IIHS Pushing for Better Headlights
by SubLGT - 12/12/19 11:58 AM
My favorite flight ever
by Astro14 - 12/12/19 11:31 AM
Does anybody else have reactions to MSG?
by Chris142 - 12/12/19 10:35 AM
injecter cleaner?
by ernied - 12/12/19 09:27 AM
Which would you use for 5k
by Bettez88 - 12/12/19 09:08 AM
Effective ways to reduce humidity inside the car
by MoneyJohn - 12/12/19 08:21 AM
Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
kalima, Powertool1994, lutvi20, Bazik, Lamasuna
70113 Registered Users
97 registered members (4WD, 53' Stude, 77GrandPrix, alchargo, 8 invisible), 1,946 guests, and 21 spiders.
Topics298,632
Posts5,139,575
Members70,113
Most Online3,589
Nov 2nd, 2019
Cant get the "D" light to stop blinking on my 2004 CRV #5263973 11/11/19 08:45 AM
N
N Heat Offline OP
N
2004 CRV 2wd 145k
About 6 months ago, the D light started randomly blinking while driving. It starts about 5 mins into a trip, and continues until the car is turned off. The tranny still shifts perfectly. Since then, Ive done a drain and fill with Honda fluid and 3rd clutch pressure switch. The fluid is acceptable level according to dipstick. At this point, Im thinking the $120 diagnostic at dealer is inevitable.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5263984 11/11/19 08:53 AM
M
mattd Offline
M
There are trouble code(s) stored.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5263993 11/11/19 09:00 AM
B
billt460 Offline
B
What exactly is the blinking "D" light supposed to signify?
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: mattd] #5264001 11/11/19 09:05 AM
N
N Heat Offline OP
N
Ive only had it checked at Auto Zone...no codes.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: billt460] #5264003 11/11/19 09:07 AM
N
N Heat Offline OP
N
Meant this a a reply to above post from BillT**
Not sure. My interweb searches came up with low fluid and 2nd and 3rd pressure switches as culprits. Usually there is a code though with the pressure switches.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5264010 11/11/19 09:14 AM
W
wag123 Offline
W
They can only pull error codes from the ECM (engine control module). You need to find someone who can pull error codes from the TCM (transmission control module).
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5264013 11/11/19 09:23 AM
L
LazyDog Offline
L
How about replacing the on line filter that sits just below the radiator and just above the sub frame.
You do need a special scanner that can read the trans codes.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: LazyDog] #5264054 11/11/19 10:08 AM
N
N Heat Offline OP
N
Is that filter a thing on the 2wd? The only filters I can find is AWD or needs tranny disassembly for changing.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: wag123] #5264055 11/11/19 10:09 AM
slacktide_bitog Offline
I thought they'd have those integrated by 2004 crzy
Don't most modern automatic cars have the engine and transmission using the same computer?
Transmission codes would show up on OBDII as P07xx
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: wag123] #5264056 11/11/19 10:09 AM
N
N Heat Offline OP
N
A reputable shop with a scan tool?
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5264057 11/11/19 10:11 AM
discountdon Offline
2004 CRV 2wd 145k
Probably VARNISH on solenoids or valves... here's what I did and the flashing 'D' never came back:
https://www.bobistheoilguy.com/foru...onda-5-speed-automatic-trans#Post5252440
Chances are your ATF fluid is tired and worn out, and you never mentioned its service history or mileage.
You could also try Lubegard Red, as it also has some cleaning action.
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to drivetrain immortality
planned obsolescence WWFis traitorous to the world
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5264097 11/11/19 11:00 AM
L
LazyDog Offline
L
The filter is inline filter that is on one of the lines going to trans cooler in the radiator.
Just do a quick google search to find it, very easy to replace just 2 clips.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: slacktide_bitog] #5264120 11/11/19 11:34 AM
H
hallstevenson Offline
H
I thought they'd have those integrated by 2004.
That is correct. We have a '99 Accord and my inexpensive ODBII adapter and Torque Pro can give me transmission codes.
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: N Heat] #5264125 11/11/19 11:38 AM
H
H
About 6 months ago, the D light started randomly blinking while driving ... 3rd clutch pressure switch.
Why did you replace that switch ?
Re: Cant get the "D" light to stop blinking on my 2004 CRV [Re: hallstevenson] #5264136 11/11/19 11:48 AM
N
N Heat Offline OP
N
It appeared to be the leading cause of the flashing D according to my internet research. I figured for $20 and 15 mins it was worth a shot.
