Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Am I Evil?
by A_Harman - 12/07/19 01:58 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
High school football championships
by 53' Stude - 12/07/19 10:57 AM
It's raining in the Bay Area
by JeffKeryk - 12/07/19 10:28 AM
No passenger tires on LT
by otis24 - 12/07/19 10:23 AM
Subaru Robin 653cc Oil coming out air breather
by Steve_NC - 12/07/19 08:17 AM
Aircraft related, what would you do with $52K?
by Exhaustgases - 12/07/19 05:43 AM
Chevy Suburban on Hollywood walk of fame
by GMguy84 - 12/07/19 05:25 AM
Mills Fleet Farm Havoline & Rotella Sale with Rebate
by Nitronoise - 12/06/19 11:44 PM
85w90 vs 75w90
by Rohan - 12/06/19 11:24 PM
Milwaukee Ratchet & Impact wrench $200
by Deere John - 12/06/19 11:17 PM
Carfax report 😳
by kstanf150 - 12/06/19 08:55 PM
2010 Honda Element 197k miles valvetrain pictrures
by SLO_Town - 12/06/19 08:31 PM
ADBV Failure FRAM ULTRA XG-8A ,10K miles 13 months
by wrcsixeight - 12/06/19 08:29 PM
MxTale, icemanrrc, Cobby, nzeroesc, Steve_NC
70059 Registered Users
102 registered members (andyd, 4WD, 97prizm, apollo18, AndyB, 69 Riv GS, 8 invisible), 2,736 guests, and 70 spiders.
Topics298,407
Posts5,134,846
Members70,059
Most Online3,589
Nov 2nd, 2019
Shelf life of sealed bearings #5263917 11/11/19 07:48 AM
L
ledslinger Offline OP
L
I just bought 2 Mopar hub/wheel bearing assemblies made in 2001. Then I remembered the shelf life of grease is recommended by some manufacturers as 5 years. Should I be worried that 18 year old bearings grease has deteriorated and may not protect? Also seals could also have deteriorated in that time.
SKF recommends a shelf life for sealed bearings at 3 years. I already bought them and am going to run them, but wonder if I should think more about sealed bearing manufacture date when making future purchases.
Like Steve Martin's character in "The Jerk" who got the latest vintage wine because after hitting the big time he could afford the "fresh stuff" should manufacture date of sealed bearings be considered?
Re: Shelf life of sealed bearings [Re: ledslinger] #5263930 11/11/19 08:07 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I guess all the older cars on the road didn’t get the memo.
While I can grease my front bearings on my Mercedes cars, the rears are all sealed and are far more than 3-5 years old.
The question is did they somehow cheapen the assembles in a way that makes the 2001 units more desirable, old grease and all?
Any signs of grease separation? Oil leaks? How do they roll?
Re: Shelf life of sealed bearings [Re: ledslinger] #5263933 11/11/19 08:13 AM
B
Bailes1992 Offline
B
I'm sure they would be absolutely fine. Although, I'm sure I rear a thread on here not long ago where people were popping out the seals and packing sealed bearings out with fresh grease.
19 Volvo V40 D3 Auto - 96 Defender 300TDi - 03 Ford Mondeo ST 3.0 V6
Engine - Castrol Edge 5w30 LL
Manual - Fuchs Sintofluid 75w80
ATF - Comma MVATF
Diff & Transfer - Fuchs Sintopoid 75w90
Re: Shelf life of sealed bearings [Re: ledslinger] #5263934 11/11/19 08:13 AM
L
L
I haven't gotten them yet. They are OEM assemblies made in USA. I suspect they will be tight and leak free.
Re: Shelf life of sealed bearings [Re: ledslinger] #5264090 11/11/19 10:47 AM
Chris142 Online Content
Online Content
Does it matter if they are put in use? My 02 Wrangler is still running the OE hubs it had when I bought it. 178000 miles ago!
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Shelf life of sealed bearings [Re: ledslinger] #5264186 11/11/19 12:51 PM
Dave9 Offline
Typical degradation of grease not stored in a hostile environment is oxidation or separation. The seal makes a big difference, either they are leaking or they aren't. If they aren't, put into use they will mix the separated oil and solids back together. However after this long a period they should be examined closely because they could have leaked many years ago and now only have a hard residue left behind as evidence, OR the hard residue could be an oil coating put on at the factory to retard rust (would be more uniform over the entire piece, not just on the bottom from a gravity leak), which is another reason some parts have a recommended shelf life - they don't want their product looking rusty even if functionally it wouldn't matter.
Re: Shelf life of sealed bearings [Re: Dave9] #5264420 11/11/19 05:41 PM
Marco620 Offline
Good point. Never thought about it like that.
15' Civic 1.8 i-vtec 292920 mi Redline 0w20 & LG Biotech, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Doberman,CZ's & SONY Aficionado
Re: Shelf life of sealed bearings [Re: ledslinger] #5266808 11/14/19 08:56 AM
L
L
They arrived with no sign of grease separation and leakage. I paid a premium for OEM and wish I would have considered shelf life and bought cheaper and newer parts instead of these. I doubt I'll have any problems, but still have some regrets.
Re: Shelf life of sealed bearings [Re: ledslinger] #5281403 11/30/19 06:52 PM
L
L
I changed the one that I suspected was noisy, but I wasn't sure. Before I removed the suspected one, I ran the car with the wheel removed and the hub spinning while on a jack stand. The noise was pretty loud from the drivers seat, when the tire was on the ground, at about 35 MPH. Spinning in the air, the noise was minimal, even putting a socket extension on the housing and up to my ear.
I'm amazed that a bearing that transfers so much noise when loaded, barely makes a whirring while spinning in the air. I wish had some kind of roller fixture to set the tire on to load the bearing while the wheel is driven.
Happy I replaced the correct one.
