Originally Posted by GoldDot40
Originally Posted by ecotourist
In ...
I have one of those in my attic. Have it on a thermostat switch that kicks it on at 110°F and blows the hot air out one end of the roof until the temp falls back to 95°F. I also have vents which allows heat to radiate up and out. I have it mounted on rubber insulators so I can't even hear it come on. A/C runs less in the Summer since I installed it. House was built in 2016 and it's well insulated. I even insulated the garage door too which made a huge difference inside there as well.
-Im curious what "kit" you chose to do the garage door?
There are a couple of them out there or did you do your own thing?
I did insulate the garage ceiling in my DR Horton home last year, made a difference for sure, I have been at a lost as to which garage door insulation is best.
-I spent the day yesterday insulating a complicated part of a second floor room (correcting the builders mistake)It was rough crawling across rafters on a low part of the roof etc.
I dont blame them really and see by what the insulation people did how the mistake was made but I had about 8 feet or so of uninstalled wall, also above my Master Ceiling some areas were very shallow, again, because it was a trey ceiling it was the part that slopes down. The main part of the house is extremely well done for sure, where it is a flat ceiling all across. (that is another whole story though, when we moved in, I measured the ceiling insulation and it was short of what the contract called for, had them come back and add a lot more) they actually had a paper ruler showing the depth of the insulation, thing is, at the bottom of the ruler under the insulation, it was folded, making it look like there was more insulation then there was.
-In NY I had an attic fan, thought about adding one here in the south, our roof is so big I wonder how much difference it would make, in addition unlike NY this one is well ventilated.
I suspect it would make a big difference, we have two AC units and all the duct work up there. You know, if I knew someone who I know would do a 100% correct job cutting a hole in my roof I would be more tempted.
Anyway, really curious where you got the garage door kit. I know HD and Lowes sell them. I actually bought my own foam board some time ago, I gave up on the idea though, measuring and cutting isnt my thing and need it to look professional. I know many people can do that, I need a kit *L*
