Hello.
I have a 07 charger R/t with about 310k original miles and about 70k miles on the reman engine replacement from 3 years ago.
I travel with my job about 2000 miles a month.
I've been using Mobile 1 5/20 full Synthetic 20k protection.
With the same filter.
I'm noticing at about 1000 miles I'm losing 1qt of oil about 1.5qt of oil at 1500 miles.
Is this normal?
If so, what can I do to prevent this ? Should I switch to a heavier weight?
Or is it some type of additive I could use each oil changed to prevent this from happening.
Is this normal?
