Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
Limitations on bluetooth OBDII scanners?
by jayjr1105 - 01/20/20 03:27 PM
Quaker state 5w20 $1.50
by Villalobos - 01/20/20 02:00 PM
Heavy Calibers
by rrretiree7 - 01/20/20 01:09 PM
Filter Efficiency Specs
by Talent_Keyhole - 01/20/20 01:05 PM
Larger filter for 19 Ram
by Schwifty - 01/20/20 12:52 PM
Duralast Max Ceramic Pads Photos!
by NASTI - 01/20/20 11:23 AM
expensive rotors
by Donald - 01/20/20 11:19 AM
3 Fram Ultra's Cut Open
by jetman - 01/20/20 10:31 AM
Standard Cab Commercial
by Duffyjr - 01/20/20 10:17 AM
The thin grease for firearms
by fnbrowning - 01/20/20 10:07 AM
Replace coil packs with spark plugs?
by jayjr1105 - 01/20/20 09:34 AM
Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
ckinch1, EAC1, Kronguy, jamespeter26, RSH
70491 Registered Users
112 registered members (Aichiguy, 53' Stude, 750IX, AandPDan, 67ZL1, 13 invisible), 2,611 guests, and 27 spiders.
Topics300,362
Posts5,174,181
Members70,491
Page 1 of 3 1 2 3
Lots of metal in 2016 Charger 3.6L engine oil filter #5263093 11/10/19 07:57 AM
wwillson Offline OP
Administrator
Administrator
I changed the oil in our 2016 Charger with the 3.6L Pentastar yesterday. This run was 9,000 miles and 10 months with M1 0w-30 AFE. If you've read my recent oil change posts, you'll know that I now always drain and cut the oil filter to look for metal flakes. Since I've been doing this, I find metal in EVERY oil filter I cut. It doesn't matter how many miles in the vehicle or oil, I always find metal flakes.
My procedure is to let the filter drain after cutting, or if it's a cartridge filter, like the charger, just let it sit for a while. Then cut the end caps off so I can release the media, cut the media so you can lay it out flat. Go outside in the bright sunlight, face away from the sun and pull the media tight, then move the media so it slightly changes the angle to the sunlight. If you do this, you will always see some small metal flakes. I wish there was a way to get a good video of this, which I might try sometime. Pictures do almost no good, because you can't see what happens when the sunlight angle is changed.
This filter run for 9,000 miles and 48,000 miles on the car, had the most metal I've ever seen in a filter, like 10 time more than I've ever seen. This car gets no long trips, instead gets driven to work about 8 miles each way and is our short-trip run around town car. So that's 9,000 miles of short tripping. I will cut the filter in the spring to see how it looks and follow up.
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263110 11/10/19 08:15 AM
G
gfh77665 Offline
G
Any perspective on overall durability and longevity of the 3.6 Pentastar?
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: gfh77665] #5263121 11/10/19 08:21 AM
wwillson Offline OP
Administrator
Administrator
The Pentastar in my Durango, which has 110,000 miles, has been flawless. I believe that the Pentastar is mostly flawless. Keep in mind that the Pentastar in the Charger has also been flawless, I'm just finding lots of metal flakes in the filter.
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263125 11/10/19 08:23 AM
I
Imp4 Offline
I
Take a video with your phone. Upload to YouTube and post a link to the video...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263128 11/10/19 08:28 AM
Sunnyinhollister Offline
Out of curiosity, what was the OLM reading?
2017 Ram 1500 Regular Cab 4x2 5.7L 8spd
2017 Chevy Bolt
2018 Jeep Cherokee Trailhawk
2004 Toyota Highlander AWD - RIP
2001 Ranger XL 4x4
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: Sunnyinhollister] #5263131 11/10/19 08:32 AM
wwillson Offline OP
Administrator
Administrator
3% left
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263137 11/10/19 08:37 AM
I
incognito_2u Offline
I
Have you had an UOA done? And if so, what does it look like?
2006 Jeep Commander 3.7 V6 -115k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -86k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -88k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (QSUD5W30/XG3600)
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263145 11/10/19 08:50 AM
B
BAJA_05 Offline
B
What kinda oil filter?
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263147 11/10/19 08:53 AM
3% left
Wow! I'm surprised it went 9K on the OLM with it being short tripped. I was going to order magnetic drain plugs for the Ram and Cherokee so it will be interesting on how they look after an oil change.
2017 Chevy Bolt
2001 Ranger XL 4x4
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: Sunnyinhollister] #5263151 11/10/19 08:56 AM
4WD Offline
Me too … only engine I ever saw flip an oil in 3k of mostly short trips …
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263156 11/10/19 08:59 AM
N
NormanBuntz Offline
N
Personally I would never run the OLM down to 3%. Oil is cheap. I prefer shorter intervals especially with short tripping.
Firesign Theater: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 10K, 2nd owner
2007 Honda Ridgeline RTS, 96K, 1st owner
2007 Infiniti M35, 115K, 1st owner
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263168 11/10/19 09:12 AM
danez_yoda Offline
how are you cutting open the filters? is that the souse of the shavings.
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: danez_yoda] #5263170 11/10/19 09:15 AM
4WD Offline
Pentastar has a housing right on the front/top of motor with a cartridge filter
(best location ever !)
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263175 11/10/19 09:26 AM
F
FastLane Offline
F
Not surprised with such long OCI.
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Lots of metal in 2016 Charger 3.6L engine oil filter [Re: wwillson] #5263227 11/10/19 10:13 AM
J
JTK Offline
J
Having owned two pentastars at this point, my 2013 Grand Caravan and my current 2017 Ram 1500, the oil life monitor doesn't seem to be all that sophisticated. I don't know how the algorithm works on it, but it doesn't seem like they count down faster with short trips, very cold starts, etc. I too have found that they'll go out to 8-9K miles taking them to 0% life left. I can't do it and tend to change at a 6K mile OCI or less with my ultra high quality Napa or Supertech synth oil.
I too have found very fine and few metallic particles in the filter media, but found that to be the same on any filter I cut open and examine for enough time in the right lighting. You can't see it under normal shop lighting.
I don't know if it does any good, but I run synthetic 5w30 in my pentastars as opposed to the recommended 5w20. Same with my new Nissan VQ35DD that recommends 0w20. Nope.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Page 1 of 3 1 2 3
