Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
JimNastic316, Jimbobert56, Ollie_B_2000, akarip, BJD2020
70804 Registered Users
115 registered members (2015_PSD, 53' Stude, 14Accent, Anduril, 928, 10 invisible), 2,074 guests, and 18 spiders.
Topics301,948
Posts5,206,118
Members70,804
02 ALH TDI Jetta...which oil? #5262773 11/09/19 06:58 PM
dx92beater Offline OP
Supposed to be getting this car from a co-worker soon. Has 180k miles. I know jack about diesels but the price is right.
What are some good oil choices?
Thanks.
Galant VR4, Talon TSI AWD, Forester XT, Caravan AWD, Focus, GMC Truck
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262775 11/09/19 07:01 PM
K
kschachn Online Content
Online Content
K
A good choice is one that carries the approval listed in the owner's manual. What does it say? Grade is going to be largely irrelevant.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: 02 ALH TDI Jetta...which oil? [Re: kschachn] #5262786 11/09/19 07:13 PM
I don't know what it says. Do you? I am not working today, tomorrow, or Monday. I won't see my co-worker until Tuesday or so. Until then, I came here for some suggestions and ultimately the technical answers that I will get.
It doesn't say that I should use Rotella T6 in my Forester XT either, so I came to BITOG to find out that there are many in the community which use it. I can't stand the RTFM posts here, especially when I don't have the manual.
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262795 11/09/19 07:27 PM
supton Offline
OP, head over to tdiclub.com and hang out there. I haven't owned a TDi in years, and don't remember what an ALH needs, but there should be a bajillion threads on what to use over there. Along with gobs of other info.
This is a manual trans, right? I forget if that year had a good clutch or not. The DMF's like to go, and an SMF is often a nice upgrade. Now if it's the 4AT... well, as long as you get the car cheap then great. It'll probably last... maybe.
Don't forget, it's a timing belt, and an interference motor at that. IIRC no one trusted the motor when the belt broke; it was grounds for head removal, as one never knew.
Might want to look into VAG-COM for an OBD reader.
Good cars, I still miss mine at times.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262822 11/09/19 07:59 PM
P
pezzy669 Offline
P
I had an '03 Golf TDI many years back.
Back then the ALH TDI really liked Mobil Delvac 5W-40 and Shell Rotella T6 5W-40. The formulas have changed so my advice was applicable as of 15 years ago. My ALH had amazing oil analysis results on Delvac 5W-40.
You don't have the pump duse (04-08) valvetrain issues to worry about nor the DPF of the common rail cars (09+) so your options are pretty much unlimited.
2012 Volkswagen Jetta Sportwagen TDI - 69k - Castrol Edge Professional LL03 5W30
2011 Volkswagen Jetta Sportwagen TDI - 49k - Castrol Edge Professional LL03 5W30
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262835 11/09/19 08:15 PM
Thanks very much for the thoughts. I subscribed over at the tdiforums but I am awaiting moderation approval.
Unfortunately, it is the A4. I have heard some bad things about them. Appreciate the comments guys.
The car is $500 bucks and this is a higher cost of living area so I figure this is a good deal. Apparently, there are places who do the 5 or 6 speed conversion bringing up the MPG up by around 8 which would also make it worth it. I'd do the conversion myself but too doggone busy.
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262856 11/09/19 08:40 PM
M
maxdustington Offline
M
It sounds easy until you find out you need a matching cluster and ECU from a stick car, or an ECU with immo delete. The TDI trans also has different gear ratios IIRC. Might not be that cost effective in 2019 unless the rest of the car is mint or you are an enthusiast.
99 Toyota Tercel CE 5EFE/C151
PUP 5W30/Ultra
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5262898 11/09/19 10:11 PM
P
pitzel Offline
P
Those engines gained some notoriety for intake clogging, which was heavily believed to be significantly the result of dealers servicing them on relatively short intervals with bulk 5W-30 dino. The intake clogging issues being very similar to what people with modern petrol-fired DI engines are experiencing.
MAFs were an issue as well. Very sensitive. Window regulator hardware as well was flimsy.
Delvac-1 5W-40 was pretty much the 'go-to' recommendation on tdiclub at the time and the UOA's came out well. Any diesel-rated synth xW-40 probably would be just fine at this point.
The 6 speed conversion, probably would never pay for itself at this point.
The TDIclub people have beaten the h*ll out of them over the years, so probably every problem imaginable has been encountered except some age-dependent ones. Check for rust to make sure you're not buying something that has to be junked immediately on grounds of safety.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: 02 ALH TDI Jetta...which oil? [Re: kschachn] #5262900 11/09/19 10:13 PM
U
UG_Passat Offline
U
The owner's manual is largely outdated.
Grade is relevant as it is listed in the owner's manual.
5w40, with VW 505.00, ACEA A3/B4, or API CF-4 or CG-4.
I had a 02 Golf TDI.
So, what oil to go with? A HDEO 5w40 oil will be fine, Shell Rotella T6 5w40, Chevron Delo 400LE 5w40, etc Those will be more than enough for the factory 10,000 mile OCI.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: 02 ALH TDI Jetta...which oil? [Re: pitzel] #5262903 11/09/19 10:17 PM
U
UG_Passat Offline
U
Intake clogging was common when the diesel had a lot of sulfur, which produced a lot of soot. Combine that with the EGR, where it starts clogging at the EGR into the intake manifold (not the valves). Deleting the EGR was common, but it also removed the shutoff flap. An easier mod was the "EGR mod" which reduced the duty cycle on them, virtually eliminating the buildup.
The gas intake valve buildup on the VW/Audi DI's, there is no EGR valve, that you can address. the EGR is simulated with valve timing/overlap.
Re: 02 ALH TDI Jetta...which oil? [Re: pitzel] #5263124 11/10/19 08:23 AM
M
M
Most likely has been dealt with on a seventeen year old car, might have even gotten the updated clips from the factory. My friends have had 02s one even a 02 ALH and they never complained about the window clips, but I had to replace them on my 2000 2.slow. I'd be more concerned with the rear beam bushings than window clips if we are talking about early MK4 foibles.
PUP 5W30/Ultra
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5263192 11/10/19 09:44 AM
A
Audios Offline
A
I have used M1 5/40 TDT, Motorcraft 10/30, Rotella T6, using T5 10/30 now. All worked fine for my 5k interval, Ive posted the analysis before, you can search my posts or look in the used diesel analysis section. Theres another member running T6 for almost 15k if I recall correctly!
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: 02 ALH TDI Jetta...which oil? [Re: maxdustington] #5263205 11/10/19 09:55 AM
U
UG_Passat Offline
U
My 02 had plastic window clips. Dealership was nice enough to replace them with the metal clips before it broke upon my request. (hence buying 2 more VW's from that dealership)
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5263334 11/10/19 01:01 PM
A
Audios Offline
A
Long term, the cost of the upgrade isnt really worth it, 8 mpgs extra (at best) on an all highway ride would only be about 100 miles, so roughly 5$ of fuel per tank best case, for something that will probably cost $2000 up front. I recently hit 44 mpg on an 800 mile trip to maine, I have nozzles and 2.5" exhaust with high flow cat, so its a bit peppier than stock.
Re: 02 ALH TDI Jetta...which oil? [Re: dx92beater] #5264123 11/11/19 11:36 AM
R
Roost426 Offline
R
My dad has a 2005 golf tdi, I have him running either Rotella T6 5w-40 or Mobil 1 Turbo Diesel truck 5w-40 depending what he finds when he needs an oil change. I think as mentioned above his motor is the one that is harder on parts so you are probably open to some other oils as well. cool
1990 Dodge W250 5.9 Cummins - VPB 15W-40,MO-285
1986 Ford F350 6.9 IDI - ST15W-40,MC FL1995
1987 Jeep Comanche 4.0L - Mobile Super 5K HM10W-40,Fram TG8A
1993 Ford Ranger 2.3L - RGT5w-30,Fram FPS8A
