Which brake pads for towing?
by pburchett - 06/06/20 08:27 PM
supertech 0w16 $11/ 5 qt
by eljefino - 06/06/20 07:55 PM
Pennzoil 5W-20 HM Ecobox? $2.27????
by Jackson_Slugger - 06/06/20 07:50 PM
Fluid for Jeep electric-boosted spower steering?
by Jeffrey Behr - 06/06/20 06:33 PM
Bottom grill hitting radiator fan
by dan765 - 06/06/20 06:26 PM
Unknown mystery oil
by Zgrant231 - 06/06/20 06:23 PM
Paint Protection Film (PPF)
by HDoilDude - 06/06/20 05:40 PM
Old RedMax EBZ8001
by BISCUT - 06/06/20 04:57 PM
ATF as general purpose oil?
by buck91 - 06/06/20 04:29 PM
Silicone vs fumed silica?
by buck91 - 06/06/20 04:24 PM
e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
Jeancando, SkulltulaHouse, geekofband007, jproposki, 1mzsludge
71625 Registered Users
96 registered members (ammolab, antonmnster, 2015_PSD, aquariuscsm, 77GrandPrix, 13 invisible), 1,939 guests, and 31 spiders.
Topics306,313
Posts5,289,985
Members71,625
Page 1 of 5 1 2 5
Why so many bad CVT trans? #5262725 11/09/19 07:12 PM
R
red7404 Offline OP
R
why is there so many bad CVT transmissions sold to the public? and ill not even talk about fords duel clutch mistake.
Re: Why so many bad CVT trans? [Re: red7404] #5262732 11/09/19 07:19 PM
Nick1994 Offline
Yeah those Ford Dual Clutch CVTs are the worst LOL
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Why so many bad CVT trans? [Re: red7404] #5262737 11/09/19 07:22 PM
JohnnyJohnson Offline
Lots of Stealership money in maintenance and it helps cars wear out before their time. There is no reason to have an automatic transmission that is maintained correctly to last less than 300K.
2004 Corolla 140120
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Why so many bad CVT trans? [Re: Nick1994] #5262751 11/09/19 07:35 PM
J
JTK Offline
J
Especially them duel ones. fence
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Why so many bad CVT trans? [Re: red7404] #5262760 11/09/19 07:46 PM
A
AC1DD Offline
A
Thing is that over in Europe, and in the ROW Ford was using a "wet clutch" DCT which had NO issues whatsoever. The reason Dearborn specified a
"DRY clutch" version of the DCT was because it was slightly cheaper....and it also was almost an issue on every car that came with it. Seems to me like
if Ford Cologne designed a car, they shouldn't let Ford Dearborn mess with it.
That being said a good quality traditional geared slushbox will last for 300,000 miles they are a proved design and the good ones are almost impossible to kill.
OTOH the CVT is not proven and many of them wear out under 100k even if not abused. They are NOT a proven design, unless you are putting them in a golf cart.
Re: Why so many bad CVT trans? [Re: AC1DD] #5262793 11/09/19 08:27 PM
L
littlehulkster Online Content
Online Content
L
Toyota has been using CVTs in their hybrids for over a decade now and not only have they had no significant issues, the Prius one of the, if not the most reliable car you can buy and has been it's entire existence. This is despite the Prius getting heavy use as a fleet car in cities and racking up god even knows how many miles.
CVTs can be fine if they're not designed by idiots.
Before you counter with the low power argument, I will also point out Toyota CVTs have been used in huge V8 Lexus limos with over 400hp and still have no significant problems.
2015 Mazda3 I 2.0
Re: Why so many bad CVT trans? [Re: red7404] #5262794 11/09/19 08:27 PM
W
WondrousBread Offline
W
Like any new technology, there will be a transition period where they are less reliable than the previous iteration of the technology. As the problems are ironed out, they'll become more and more reliable.
Anecdotally, my mother has a 2010 Sentra with the CVT, and it is quite happy at 250,000km with only one fluid change from the dealer. I can only imagine that with her incredibly gentle driving habits it has been the ideal situation for CVT lifespan.
Re: Why so many bad CVT trans? [Re: littlehulkster] #5262796 11/09/19 08:29 PM
supton Offline
Before you counter with the low power argument, I will also point out Toyota CVTs have been used in huge, stretched Lexus limos with over 400hp and still have no significant problems.
At least in the early Prius's the trans was not a CVT. By summing engine speed with electric motor speed they could vary the speed of the car and motors. I think recently they added a speed, but those early ones were not a CVT in this sense.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Why so many bad CVT trans? [Re: supton] #5262798 11/09/19 08:30 PM
L
Online Content
L
Even in the first Prius it was a planetary gearbox, however Toyota calls it a CVT and always has. It's different from most, but it's still a CVT.
2015 Mazda3 I 2.0
Re: Why so many bad CVT trans? [Re: red7404] #5262808 11/09/19 08:45 PM
M
madRiver Offline
M
No idea what bad means? Unreliable? poorly executed ?
Re: Why so many bad CVT trans? [Re: red7404] #5262839 11/09/19 09:17 PM
demarpaint Offline
popcorn
God Bless Our Troops
Re: Why so many bad CVT trans? [Re: madRiver] #5262841 11/09/19 09:20 PM
A
AC1DD Offline
A
The CVT is an inherently flawed design when used in heavier vehicles, that's why Toyota and others have had to make lots of changes. The only vehicles they seem suited to with expectations of 100k durability are fairly light weight in nature.
It's pretty clear to me that the manufacturers are determined to not give you a choice of power trains in the future by making the CVT the only choice of transmission.
You can see this same arrogance with the EV.
A very interesting thing I have noticed in some well known car forums is that if you disagree with EVs being viable or popular they will BAN your account major
censorship is occurring.
Re: Why so many bad CVT trans? [Re: red7404] #5262846 11/09/19 09:26 PM
PimTac Offline
Anyone have extra popcorn?
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Why so many bad CVT trans? [Re: AC1DD] #5262848 11/09/19 09:27 PM
L
Online Content
L
Lexus has put it in vehicles weighing well over 5000 pounds with 400HP and AWD with no trouble. The Lexus LS, hybrid or no, is SIGNIFICANTLY more reliable than any comparable luxury sedan equipped with any other transmission.
For such a flawed design, it's amazing that Toyota can make it considerably more reliable than anything the Germans have ever done.
2015 Mazda3 I 2.0
Re: Why so many bad CVT trans? [Re: red7404] #5262869 11/09/19 10:04 PM
Marco620 Offline
Got 286,000 miles on original cvt transmission from Honda rocking Castrol Transmax or Redline CVT Fluid. Changing every 20-30k.
15' Civic r18, 337,000 mi M1 0w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Gumout PEA
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
Page 1 of 5 1 2 5
