Forums Migration
Please read this thread
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
104 registered members (2003f7, aquariuscsm, 2009Edge, alarmguy, 97tbird, 55hambone, 13 invisible), 1,935 guests, and 26 spiders.
Topics307,567
Posts5,313,264
Members71,876
What happened to the tires? #5262520 11/09/19 01:15 PM
I
itguy08 Offline OP
I
Out camping this weekend and noticed that one of the trailer tires looked to be way overinflated. The tread along the whole tire was bulging up like the tire had 100lbs of air in it. The tread was not flat like the other tires. I got the gauge out and it was actually about 10lbs low which considering we're in a very cold snap makes sense. Put on the spare and it looks like the others again.
Any ideas what happened? Blew a belt? They are radials so there's no way it should have looked like that unless something internally blew out...
Re: What happened to the tires? [Re: itguy08] #5262521 11/09/19 01:16 PM
F
FordBroncoVWJeta Offline
F
Pictures?
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: What happened to the tires? [Re: itguy08] #5262523 11/09/19 01:19 PM
Chris142 Offline
Belt broke or tread separation.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What happened to the tires? [Re: itguy08] #5262527 11/09/19 01:25 PM
F
Finklejag Offline
F
Cheap Chinese tires flooding the market.
Re: What happened to the tires? [Re: itguy08] #5262536 11/09/19 01:38 PM
I
Imp4 Offline
I
Sounds like a manufacturing quality issue.
Pictures???
Re: What happened to the tires? [Re: Finklejag] #5262619 11/09/19 04:16 PM
spasm3 Online Happy
Online Happy
I am going to change the tires on my new TT this winter. I only trusted them for 1 season. Going to go with goodyear endurance.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: What happened to the tires? [Re: Finklejag] #5262626 11/09/19 04:24 PM
CT Rob Offline
This ^^^^^
2017 Toyota Tundra SR5 Crewmax 4x4 Trd offroad.Inferno Orange.All stock for now....
Re: What happened to the tires? [Re: itguy08] #5262629 11/09/19 04:33 PM
CapriRacer Offline
You had a tread separation - typically the top belt separates from the bottom belt.
How old are these tires? On the RV websites I frequent, they report that trailer tires last 5 or 6 years, then they are too old and need to be replaced.
Plus, trailer manufacturers didn't do a good job of sizing the tires - not enough load carrying capacity.
Then there's the issue of being 10 psi underinflated.
You might want to consider replacing all the tires. The latest is that the Goodyear Endurance series seems to be the only tire to have solved all the trailer tire issues.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: What happened to the tires? [Re: spasm3] #5262673 11/09/19 05:39 PM
K
KenshinHimura Offline
K
I believe that the Endurances are made in the USA
1997 Mitsubishi Eclipse Spyder Valvoline Max Life HM Full Synthetic 10w30 Napa Platiunum
2019 Hyundai Veloster Turbo QS 5W-30 OEM filter
Re: What happened to the tires? [Re: itguy08] #5262811 11/09/19 08:48 PM
I
itguy08 Offline OP
I
Thanks. Don't have pics but I'll try to get some up tomorrow. Basically the whole tread is raised in a domelike pattern throughout the whole tire. Kind of reminded me of a bike tire where it's domed vs flat like a car/truck tire.
Tires are the original WestLakes from the trailer which was manufactured in April 2015 (we ordered it) so they are either early 2015 or late 2104 vintage. About 12k miles on them.
I do keep up with the pressures and check them regularly. We're in the NE and the tires were just aired up a couple weeks a ago in the 50's. Last night it was 17 in the campground and I think I checked the pressure when it was in the low 30's.
Plan is for 5 new tires next camping season - they will be 5 years old then. Not sure what to go with - thinking Carlisle or Goodyears.
Re: What happened to the tires? [Re: itguy08] #5263007 11/10/19 05:46 AM
T
totegoat Offline
T
Les Schwab warranted and replaced several tires on my trailer as they delaminated. If I were buying trailer tires today I'd look at the Made in USA Goodyears.
Re: What happened to the tires? [Re: itguy08] #5263042 11/10/19 07:43 AM
F
Fawteen Offline
F
It didn't take long to find a bit of information about WestLake tires from 2014-right about the time those tires were new.
Re: What happened to the tires? [Re: itguy08] #5263572 11/10/19 07:41 PM
I
itguy08 Offline OP
I
Here are the pics of the bad tire:
[Linked Image]
[Linked Image]
Note how the tread cups - not flat like this "good" tire:
[Linked Image]
Even my wife agreed it didn't look that good. We ended up putting the spare on for good measure and got home fine.
Right now I'm leaning toward the Carlisle Radial Trail HD tire. They have gotten good reviews in the RV forums and are decently priced. There seems to be some confusion if they are made in the USA or China but I think the QC from a name brand company would be better than not. I've got a set of Chinese made Coopers on my Taurus and they have been excellent tires.
Re: What happened to the tires? [Re: itguy08] #5263589 11/10/19 07:57 PM
CKN Offline
I don't know where the Carlisle tire are made. However the HD version has earned a good reputation on the RV forums.
Re: What happened to the tires? [Re: Fawteen] #5263590 11/10/19 07:59 PM
CKN Offline
HM...no. The Westlake tires now have the proper construction and a nylon overlay cap. Don't know about the rest. But it's rather unfair to bash tires you have no experience with by using the work "alleged". Please go back and share the date of your "copy and paste" article.
The OP's tires should have been replaced way before this...regardless of the company or country of origin. I have run all manner of Chinese ST tires. At the 4 year marked they are replaced...regardless of appearance. I have never had a single blowout....NEVER.
