a sad day for our family
by miden851 - 06/06/20 09:26 PM
pressure starts up first try after not used for 6 months
by motor_oil_madman - 06/06/20 08:50 PM
Any Recommendations For LED Shop Lighting
by walterjay - 06/06/20 08:36 PM
Which brake pads for towing?
by pburchett - 06/06/20 08:27 PM
supertech 0w16 $11/ 5 qt
by eljefino - 06/06/20 07:55 PM
Pennzoil 5W-20 HM Ecobox? $2.27????
by Jackson_Slugger - 06/06/20 07:50 PM
Fluid for Jeep electric-boosted spower steering?
by Jeffrey Behr - 06/06/20 06:33 PM
Bottom grill hitting radiator fan
by dan765 - 06/06/20 06:26 PM
Unknown mystery oil
by Zgrant231 - 06/06/20 06:23 PM
Paint Protection Film (PPF)
by HDoilDude - 06/06/20 05:40 PM
Old RedMax EBZ8001
by BISCUT - 06/06/20 04:57 PM
ATF as general purpose oil?
by buck91 - 06/06/20 04:29 PM
Silicone vs fumed silica?
by buck91 - 06/06/20 04:24 PM
e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Jeancando, SkulltulaHouse, geekofband007, jproposki, 1mzsludge
71625 Registered Users
88 registered members (4WD, bcossa2001, aquariuscsm, bbhero, 2015_PSD, 97prizm, 8 invisible), 1,801 guests, and 25 spiders.
Topics306,317
Posts5,290,034
Members71,625
Generator, 10,000W dual fuel gas & propane ?? #5262474 11/09/19 11:52 AM
W
wdn Offline OP
W
Does anyone own a dual fuel portable gas/propane generator?
Do you run it solely off of barbecue gas propane bottles, e.g. Blue Rhino? Any concerns?
Will operating on propane only be completely clean with respect to carburetor and fuel lines (which is what killed my last one, one moment of forgetfulness to shut off fuel and run it dry after 7-8 years killed my current one ). This one is electric start and runs off propane bottles or gasoline but I would be running it only with propane.
[Linked Image]
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262480 11/09/19 12:07 PM
B
billt460 Offline
B
I don't have a high capacity generator, (just a 600 watt Honda), but I would get one like you have when the time comes to buy one. Propane runs much cleaner than gasoline. Less carbon monoxide as well. Plugs will last a lot longer. And the fuel won't go bad.
The downside is the unit won't put out as much fueled with propane, as it will with gasoline. But a 20 pound tank holds around 4.6 to 4.7 gallons of liquid propane. So you can calculate your run time off that.
Remember that exchange tanks, (Blue Rhino and the like), are all short filled. Most charge a 20 pound bottle with only 15 pounds. So you might want to purchase your own tank. And maybe go with a 30 pound, or even larger tank. That way you'll have increased run time.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262524 11/09/19 01:20 PM
F
Fawteen Offline
F
Yup. A Champion 9375.
Yes and no. I have an outdoor kitchen so we always have at least 3 extra 20# tanks. An extra for the grill/cooktop, an extra for the smoker, and one more "just in case". I like the dual fuel-should we have an extended power outage (like during Michael) I can always grab a couple empty tanks and run up the highway a few miles and exchange them. Or if for some reason that's not an option, I could always switch over to gas. I have no concerns whatsoever about running it on LP.
Never had a single issue with running it off propane exclusively. The Champion doesn't have an "off" switch. In order to kill the engine you simply turn the fuel off. It stops in less than a couple seconds on propane. I get about 5 hours on a 20# tank when it's running under significant load. Running a lighter load would extend that, or running it off a larger tank would also extend that.
The problem that I see with a larger tank is that there are no exchange options. A 20# tank can be exchanged on almost every street corner (even our grocery store has the Blue Rhino exchange). But a larger tank has to be filled at a local propane dealer, which may or may not also be part of a widespread power outage.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262526 11/09/19 01:22 PM
W
wdn Offline OP
W
Thanks. I just placed the order Sam's Club is having a one day members sale. I bought it for $648 delivered which is $150 off.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262608 11/09/19 03:50 PM
spasm3 Offline
The only advantage i see to propane is that is does not go bad when stored. Propane has probably 25% less energy than gasoline so you will use more. To me its easier to store and cycle through fuel than keep tanks of propane around. Easier and more places to buy gas, unless its a huge wide spread outage.
I can keep more energy stored in less space with gasoline that i ever could with propane.
Now a generator that runs off of your natural gas supply would be great. No storage required. Always there, and no supply limit.
I have two generators, and a propane option was nothing i looked for when shopping. I may get a new larger one. I have a 20 year old 8/10k one and a newer HF 4375 . If i replace the older one, i won't be shopping based on propane. In about 15 years i will go with a permanent standby natural gas model.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262625 11/09/19 04:22 PM
spasm3 Offline
Looks like a decent price. The nice thing is, it has 240volt outlets, you could run a gas furnace. Even your clothes dryer if you have the connection, and manage your other loads.
I have to have 240 for well pump to have water. Gas heat and gas water heater. I basically can run my whole house on 8-10k except for air conditioning in the summer.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262648 11/09/19 04:58 PM
W
wdn Offline OP
W
I had a Reliance gentran installed in my basement by a professional electrician. It is the same cable plug connection as the 240V/30A socket on the new generator. It runs 2 gas furnaces a well pump, refigerator, microwave, garage openers and kitchen and upstairs hallway lights. That was before I switched to all LED lighting. The old generator was only 5,500 watts which was a bit undersized. Here the frozen north the furnaces and well pump are necessities. The gentran has 10 circuit on it.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262691 11/09/19 06:01 PM
U
UncleDave Offline
U
Had many propane gensets - no dual fuels at the moment - on purpose.
The concern you need to worry most about after load is run time.
Running on propane that genset will rip through a 20LB (filled to 80%) bottle like a puppy chewing up the morning paper.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262753 11/09/19 07:36 PM
E
eljefino Offline
E
You may have issues vaporizing enough propane in the cold to run a substantial load. Maybe get a manifold so you can run two 20-lb tanks.
I put an aftermarket propane carburetor on my "chonda" genset and it's finicky. I pretty much have to start and warm it up on gasoline. The propane regulators have a gadget in them that shuts things down if they detect leaks, which sometimes the intake pulse of the motor must feel like.
However, switching to propane to finish things really, really dries out the gas part of the carb so it's ready to go the next time. approved
4.2 gallons of propane from BJ's wholesale is around 11 bucks. Gasoline is slightly cheaper right now, gallon for gallon, but also has the advantage in energy density.
Propane wins for storage. I have a couple few bottles out in the woodshed.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262810 11/09/19 08:47 PM
A
Al Offline
A
Do you need 10KW? If you run at 5 KW...it takes 20.5 pounds for 24 hours. Most people buy bigger than they need. And consider a 5KW unit will be more efficient than a 10KW unit running at 50% Thats $54 per day
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: billt460] #5262844 11/09/19 09:23 PM
Dinoburner Online Content
Online Content
Agree
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262849 11/09/19 09:27 PM
W
wdn Offline OP
W
That’s a good point, Al. The gas one I just stupidly ruined earlier was rated 5.5 KW on gas. The new on is rated 6.5 KW on propane, but 8.0 KW on gas, the part about it is 10,000 watts is only when running on gas, peak power, or 2,000 watts of just marketing fluff. I also like eljefino’s suggestion which is run it on gas most of the time and finish with propane to dry out the carb and fuel lines. I will have to read about how easy it is to change over to the other fuel. Do you have to let it cool down first I wonder.
Thanks to all who replied. This is good info.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: billt460] #5262852 11/09/19 09:33 PM
chainblu Offline
This is true. However, a refilled tank (20 lb) is only going to have 16 pounds (7/8 full vs 3/4 full). The difference is not as big as people think.
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: chainblu] #5262873 11/09/19 10:07 PM
Online Content
Huh? Unless the OPD is defective a 20lb will accept 20 lbs of propane. Whenever you bring a 20 pounder in to TS they will measure in by the gallon while monitoring the spit gauge, AKA bleeder. To help prevent overfilling, tanks should be filled on scales noting tare weight
Kubota L5030 T6
Re: Generator, 10,000W dual fuel gas & propane ?? [Re: wdn] #5262874 11/09/19 10:07 PM
Online Content
Kubota L5030 T6
