Originally Posted by geeman789
Does more HOT oil drain out of an engine ?
Or does HOT oil, left to settle completely overnight, then drained COLD the next day get more used oil out of the engine ?
I think the second option will actually remove more oil. Any engine that has been running in the previous couple of hours will have oil throughout the engine that has not yet drained down. If I check my oil after driving the car, waiting an hour ALWAYS shows a noticeably higher level on the dipstick. Or you could let the hot oil actually drain for an hour or more ...
I've wondered that too, but... there's always a bit left in the bottom of the pan, and then there's some left in the head(s) too, places where it'll never drain on its own.
Yeah, there might be a few ounces on the walls, in the process of draining, that if you drain hot you won't get. But I strongly suspect that after 10-15 minutes of sitting, it's mostly there and just too small of an amount to be concerned with. After all, most of us are changing oil long before it's actually bad.
Sometimes I wonder if the guys who do spill and fill on their transmissions (you know, just a pan drain, not a full fluid exchange) worry about getting all their motor oil out when they change engine oil.
