Do You Fly the BITOG Flag?
by ARCOgraphite - 11/13/19 08:42 AM
Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
104 registered members (1978elcamino, 64bawagon, 14Accent, 69GTX, 28oz, Alfred_B, 8 invisible), 1,991 guests, and 19 spiders.
Topics297,342
Posts5,113,582
Members69,842
Most Online3,589
Nov 2nd, 2019
ATF smell #5262358 11/09/19 07:49 AM
B
BMWTurboDzl Offline OP
B
Post-ATF pan drop.
Q: What would cause a faint ATF odor emanating from the engine bay?
The vehicle is going to go up on a rack on Monday to check for leaks but the unit shifts fine so I suppose leak could be really small.
Could it be off gassing from the parts themselves as they heat cycle (gasket, plastic drain pan)?
The smell does not present itself when the vehicle is running and in park. Only after it has been in gear (pressurized?).
Thoughts?
It's going into the shop on Tuesday but I figured I'd ask you guys. In the mean time.
435i
Re: ATF smell [Re: BMWTurboDzl] #5262370 11/09/19 08:20 AM
Astro14 Online Content
Online Content
You splashed a tiny bit on the exhaust. The smell will fade after driving a bit more.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: ATF smell [Re: BMWTurboDzl] #5262384 11/09/19 08:42 AM
Snagglefoot Offline
Not sure about beemers but a common source of small leaks are on the transmission cooler lines where the rubber section is crimped onto the steel or aluminum line. Here’s a photo of a couple of GM lines with 180,000 miles. The leak was so slow it didn’t drip on the garage floor. I’ve since replaced the lines.
If you want the job done right......do it yourself.
Re: ATF smell [Re: Astro14] #5262392 11/09/19 08:51 AM
B
B
That's what I was thinking but on this car the exhaust is on the opposite side of the fill hole. I drove 300 miles yesterday and the smell seemed less and I will dive another 300 miles this evening. So I hope the smell reduces even more.
435i
Re: ATF smell [Re: Snagglefoot] #5262394 11/09/19 08:52 AM
B
B
Thanks.
435i
Re: ATF smell [Re: BMWTurboDzl] #5262412 11/09/19 09:19 AM
J
JeffKeryk Offline
J
In my case, paranoia that I made a mistake.
It will go away...
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: ATF smell [Re: BMWTurboDzl] #5262454 11/09/19 10:23 AM
Dave1027 Offline
The smell is probably coming from ATF on and around the pan. Once the transmission heats up the ATF left on the pan starts smelling. This is why I always hit the the pan with brake cleaner once I'm done to clean up
Re: ATF smell [Re: JeffKeryk] #5262607 11/09/19 02:49 PM
Yah-Tah-Hey Offline
It will go away...
Paranoia is a very common affliction on this forum. DENSO
Re: ATF smell [Re: Yah-Tah-Hey] #5262762 11/09/19 06:49 PM
A
AC1DD Offline
A
It will go away...
More likely justified vigilance. smirk2
Re: ATF smell [Re: BMWTurboDzl] #5264747 11/12/19 06:27 AM
B
B
UPDATE: I never made it to the shop on Monday because I caught a cold however after making a 400 mile trip in extremely light traffic it seems that I have cooked off any smell.
On side note, perhaps it's placebo but it seems these engines really do seem to be happiest at somewhere over 80-85 mph. The traffic was extremely light so there were some points where I could comfortably cruise at 90 or more. It's always nice to be able to give it a little work after spending a few months as a commuter.
435i
