Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
99 registered members (53' Stude, 1foxracing, Al, 2010Civic, 1978elcamino, aircooled, 10 invisible), 1,978 guests, and 20 spiders.
Topics297,341
Posts5,113,561
Members69,842
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Making Roundnose Perform Better? #5262251 11/09/19 12:32 AM
R
rrretiree7 Offline OP
R
Is there any truth to the tip of cutting an X into a lead roundnose for better performance? Thank you
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262257 11/09/19 01:09 AM
MolaKule Offline
Global Moderator
Global Moderator
It cant be because because it would reduce the Ballistic Coefficient and alter the center of mass.
For every action there is an equal and opposite opposite criticism. shrug
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262259 11/09/19 01:35 AM
B
bubbatime Online Shocked
Online Shocked
B
Could create fracturing ammo that fractures upon impact creating several wounding tracks. How do you think a district attorney is going to frame that up for a jury of your peers?
"The defendant couldn't just use regular ammo. No, he modified his ammo to be super deadly exploding killer bullets. "
Just buy factory ammo.
If it's for shooting birds or squirrels then knock yourself out.
2019 Honda CRV 1.5T factory bulk
2017 Chrysler Pacifica SuperTech synthetic 5W20
2013 Yamaha XT250 Valvoline motorcycle 10W40
2006 GMC Sierra SuperTech high mileage 5W30
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262261 11/09/19 02:16 AM
Shannow Offline
Backin the day,I used to modify.22 ammo with PacoKelly's "nasty noze tools.
My rifle liked CCI blue box,and with the tool I could make a semi flatnose (better target cutting and impact on small animals), all the way to what was basically a SWC deep hollow point, without changing the POI...clipping the top changed the POI ,the reforming jig didn't...bumping the OD up a little also helped accuracy.
If you are modifying factoryammo for self defence, then you areacting with intent...which doesn't look good.
If it's the truth....it can handle the pressure !!!
Re: Making Roundnose Perform Better? [Re: Shannow] #5262267 11/09/19 03:26 AM
GumbyJarvis Offline
What?
People reload all the time which is technically modifying factory ammo? I have seen plenty of FMJ labeled casings with FTX heads...
Also, people reload 45LC (and others) with homemade lead cast heads all the time? What's the difference between someone casting a lead bullet with the X pattern or them doing it to another brand of ammo?
I'm far from a lawyer but,
Intent technically starts the moment you buy the ammo, actually the moment you buy the weapon you intend to defend yourself with it if the need arises...
Anyway, the only issue I can honestly see when it comes to tooling around with already loaded ammo is that one wrong move and that thing can go boom.
Edit: also, OP, I think if the X mark worked better, these ammo companies with millions of dollars in research and development would be making them that way.
Pick up some Hornady Critical Defense, American Gunner, or Winchester Ranger you're worried about inadequate ammo
2018 RAM 1500 SLT 5.7L
Formula Shell Conventional 5w20 - Fram Tough Guard
Disabled US Army Vet
OEF 2013-2014
Re: Making Roundnose Perform Better? [Re: GumbyJarvis] #5262273 11/09/19 04:29 AM
Shannow Offline
Technically...of course...
imagine a lawyer,describing that the defendant sat over a projectile,critically sculpting a projectile to inflict more lethal damage...versus bought a box of self defense ammo.
In spite of what you and I know regarding the efficacy of either
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262276 11/09/19 04:40 AM
H
hatt Offline
H
The only way to improve performance on old weak .32 revolver rounds is to buy another gun in another caliber.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Making Roundnose Perform Better? [Re: Shannow] #5262279 11/09/19 04:56 AM
B
billt460 Offline
B
Originally Posted by bubbatime
How do you think a district attorney is going to frame that up for a jury of your peers? "The defendant couldn't just use regular ammo. No, he modified his ammo to be super deadly exploding killer bullets."
.......If you are modifying factoryammo for self defence, then you are acting with intent...which doesn't look good.
I hear this argued a lot. Especially about using reloads / handloads for self defense. While it sounds like a plausible argument, that a prosecutor might try to pick up on, in order to make someone look bad. (Mostly if there isn't anything else on the table that would). Can anyone site an actual case where a defendant in a self defense shooting trial was actually convicted because of using handloads, or "modified ammunition"? Or even having it be a contributing factor?
I'm not saying it never happened. But if it has, I've never seen, read, or heard of it. And this topic comes up constantly on self defense forums every day. It's a non logical argument, because any defense attorney could either argue himself, or else bring in someone well versed on the subject, and explain the whole theory away in 5 minutes by applying common sense.
Anyone who handloads buys their bullets from the same outfits that make the exact same bullets that go into most all modern self defense ammunition. It quickly becomes a non issue from a lethality standpoint over who assembles the rounds. Besides, most handloading manuals published today are watered down to the point factory "+P" self defense ammunition is stronger. Especially when you factor in the powder the ammo makers use. Which is a canister grade that is custom tuned for low flash, and better short barreled performance. Handloaders can't even purchase the stuff if they so desired.
And as far as, "modifying ammo". What could some clown do with a file and a drill in his garage, that would out perform what a multi million dollar ammunition manufacturer like Winchester or Hornady can produce? With a room full of ballistic engineers, and hundreds of thousands of dollars of laboratory grade test equipment? The whole argument is preposterous.
I'm not suggesting to use reloads. In fact, I selected my self defense ammo by asking a Phoenix cop what their department uses..... Which at the time were Speer Gold Dots. So that's what I keep my self defense handguns loaded with.
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262295 11/09/19 05:45 AM
A
askani79705 Offline
A
https://www.sgammo.com/product/32-s...acketed-hollow-point-magtech-ammo-32swlc
it is a under powered round , cutting a "X" isn't going to do much but get your tail in a crack. If do insist on using a .32, the above is better than a sharp stick.
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala Pennzoil Ultra 10w30 AC Delco Filter
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262301 11/09/19 05:54 AM
B
Boomer Offline
B
I remember an Ayoob column from years ago where he said that it is better from a legal point of view to have a hammerless revolver that can only be shot double action than a revolver with a hammer that can be fired single action. Why? Because of intent that a lawyer can point out to a jury if you shoot an intruder or an attacker. By cocking the hammer on a revolver before the shooting, you have shown your intent to shoot the person as soon as you cock the hammer and this can take it from self defense to a pre-meditated act. So I am always conscious of this and use a hammerless revolver as a carry gun/ home defense gun.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Making Roundnose Perform Better? [Re: Boomer] #5262312 11/09/19 06:18 AM
B
billt460 Offline
B
Unless it's an outright accident, how can you possibly discharge a weapon at someone without intent? Any prosecutor could argue you have shown "intent" as soon as your gun clears leather. When a cop in the field takes his gun out of it's holster, his reasoning isn't to make the perp healthier.
Does a person carrying a 1911 in Condition 1, show more "intent" than the same guy carrying in Condition 2?
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262316 11/09/19 06:25 AM
Astro14 Offline
No.
It won’t help.
You want a good performing bullet? Then buy factory ammo designed to optimize performance.
Here: https://www.buffalobore.com/index.php?l=product_list&c=141
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262349 11/09/19 07:25 AM
V
Vern_in_IL Offline
V
Simple people, you empty ALL of your rounds into the fool, then your INTENT was you feared for your life. nobody gives a [censored] about the action, just make sure the accuser is dead.
Yeah a "x" shape would help, the round is underpowed, but I WOULD NOT CUT IT into the bullet, I would do a lead pour and have the "x" shape in the casting, to prevent fractures. Pouring lead bullets is easy, the mold is usually wood.
Just something you need to try, and I would shoot many rounds at the range, if you do cut, then you need some sort of jig, so the "x" will be consistent. You want consistency here.
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262448 11/09/19 10:06 AM
B
Bottom_Feeder Offline
B
Dude... REALLY... please just get a pistol better suited to your purposes which appears to be CC. That museum piece you have, however 'classic' and 'interesting', should not be relied upon for personal defense.
Re: Making Roundnose Perform Better? [Re: rrretiree7] #5262455 11/09/19 10:24 AM
N
Neely97 Offline
N
The 32s&w has a nominal mv of 600 fps os it will make very little difference.
6.7 cummins, Toyota 4 runner
FUMOTO
Page 1 of 3 1 2 3
