My free mower saga continues. I swapped engines over the summer and got the mower running good!
About a month ago, I decided to run the rotted out deck mower and the bad engine up to the recycle pile at the dump. The next day I managed to drive over the good mower with my pickup (long story). It's mangled pretty good and I probably could have salvaged parts off of the one I threw out to make it work. That's what I get for de-hoarding.
So I was given a Murry self propelled mower. It, too, has the same Briggs 675 190CC engine. It has no spark. Rather than checking the coil and figuring out why it doesn't work I was going to swap the engine. But it appears the bottom of the crank may be different? It doesn't appear to be some sort of keyway I can change. Unless i'm missing something.
Is this even possible? Or should I start playing swaptronics with the coil and shroud from the crushed mower.
