BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
88 registered members (aquariuscsm, 4WD, 14Accent, A_User55555, Anduril, 9 invisible), 2,042 guests, and 61 spiders.
Topics306,135
Posts5,288,107
Members71,604
how does a tire warranty work? #5261832 11/08/19 03:11 PM
W
WhyMe Offline OP
W
moms 2017 CRV has 22500 miles on it. i did mo pre winter inspection on her car today. Her tires are down to 6/32 all around. So i estimate they should be at 4/32 around 33 to 35k. tires are bridgestone Ecopia tires with a 70k mile tread wear warranty. tire have been rotated regularly .
So how do these tire warranty work? DT is the usual place i go when i need new tires .
Re: how does a tire warranty work? [Re: WhyMe] #5261838 11/08/19 03:16 PM
Quattro Pete Offline
Are these the factory tires? If so, I'm not sure they come with the same type of warranty as tires bought from DT or other retail outlet.
Anyway, the tread doesn't wear down at the same rate throughout the tires' life. It initially wears faster, then it slows down.
You'd have to have all 4 tires wore down uniformly to 2/32" before you can ask for some pro-rated amount based on treadwear warranty. If there is any kind of uneven wear, all bets are off.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: how does a tire warranty work? [Re: WhyMe] #5261840 11/08/19 03:17 PM
H
hallstevenson Offline
H
Are these the factory-installed tires ? If so, you should contact Bridgestone to see how they handle warranty claims. A tire shop that didn't sell them may not have a clear procedure even though they could be an "authorized dealer" for that brand.
DT does sell a Bridgestone Ecopia EP422 Plus (w/ a 70k warranty), for what it's worth. Call DT ?
Re: how does a tire warranty work? [Re: WhyMe] #5261847 11/08/19 03:26 PM
W
WhyMe Offline OP
W
yep the factory tires. maybe i will stop by one and ask them .
Re: how does a tire warranty work? [Re: WhyMe] #5261858 11/08/19 03:48 PM
skyactiv Online Content
Online Content
There is ZERO tread life warranty on OEM tires, period.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: how does a tire warranty work? [Re: WhyMe] #5261863 11/08/19 03:54 PM
Online Content
Re: how does a tire warranty work? [Re: skyactiv] #5261867 11/08/19 04:01 PM
W
WhyMe Offline OP
W
Well i guess that answers the question. just gotta budget for new tires for mom next year
Re: how does a tire warranty work? [Re: skyactiv] #5261872 11/08/19 04:07 PM
Chris142 Offline
x2
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: how does a tire warranty work? [Re: WhyMe] #5261874 11/08/19 04:08 PM
Online Content
Also to note, check if there is a recall on the old tires the day you buy new ones. You might luck out.
Re: how does a tire warranty work? [Re: Chris142] #5261878 11/08/19 04:10 PM
K
kjbock Offline
K
Not necessarily true. Sometimes Honda/Acura will warranty their factory tires. The Michelin tires on my wifes MDX were covered by warranty. They wore out in ~25,000 miles. Contacted Michelin, they told me to go to any authorized seller and get them replaced. I went to Discount Tire and got a new set of Michelin tires ~50% off.
2019 Honda Civic Hatchback - Castrol 0W-30, M-1 M-110A
2015 Acura MDX - M-1 0W-20 AFE, M-1 M-110
2019 Honda Fit Sport - FF
Re: how does a tire warranty work? [Re: WhyMe] #5261885 11/08/19 04:19 PM
Spector Offline
Tire warrantie are pretty much worthless anyway, since they are prorated and they always are pro rated against the cost of the tire at full retail and you can probably buy that tire at discount less then with the warranty coverage. Useless warranty IMO. Not worth the paper they are printed on
Re: how does a tire warranty work? [Re: WhyMe] #5261892 11/08/19 04:25 PM
B
bullwinkle Online Confused
Online Confused
B
I had a set of OEM Contis go bad on an ‘03 Vibe I bought new, developed a messed up wear pattern on the inside of both rears. GM replaced the first set & checked the alignment (which was fine), when the 2nd set did the same thing I gave up & got something different.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: how does a tire warranty work? [Re: WhyMe] #5261898 11/08/19 04:28 PM
bdcardinal Online Content
Online Content
Sometimes I have seen OEM tires covered under warranty, but it is only at the discretion of the tire manufacturer. We have to take pictures and measurements and send those to the tire manufacturer who then usually says they will give $5-10 per tire after we pay to ship them in for inspection.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: how does a tire warranty work? [Re: WhyMe] #5261900 11/08/19 04:28 PM
K
kjbock Offline
K
[quote=WhyMe]moms 2017 CRV has 22500 miles on it. i did mo pre winter inspection on her car today. Her tires are down to 6/32 all around. So i estimate they should be at 4/32 around 33 to 35k. tires are bridgestone Ecopia tires with a 70k mile tread wear warranty. tire have been rotated regularly .
I would contact Bridgestone and see what they will do.
Honda Tire Warranties
Re: how does a tire warranty work? [Re: WhyMe] #5261915 11/08/19 04:52 PM
A
Audios Offline
A
Check the tire warranty information that should come with the owners manual. Most times they want proof of rotating every xx miles, tread depth etc. Continental used to be really good for standing behind it, it would be 2 pictures of DOT and damage to tire, tread depth in each groove, original purchase date, and mileage on tire. They would usually warranty almost every single one that had issues. This was also in the beginning of the DWS timeframe, and soft sidewalls were known, so they didnt really fight.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
