Forums Migration
Please read this thread
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
102 registered members (2003f7, aquariuscsm, 2009Edge, alarmguy, 97tbird, 55hambone, 13 invisible), 1,945 guests, and 26 spiders.
Topics307,567
Posts5,313,264
Members71,876
Does hydraulic fluid absorb moisture like brake fluid? #5261734 11/08/19 12:56 PM
A
atikovi Offline OP
A
Just changed the fluid in my '95 Mercedes convertible probably for the first time, and it was clean with no sign of corrosion on the pump metal parts. The external metal has surface corrosion. Did have some sludge on the bottom of the reservoir so I'm glad I changed it. I'd guess this fluid doesn't absorb moisture. Another use for the MityVac.
[Linked Image from fototime.com]
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261740 11/08/19 01:07 PM
U
UrS4 Offline
U
No.
Most hydraulic fluids are designed to NOT mix with water.
1993 Audi S4 2.2 20V Turbo - German Castrol Edge FST 0W-40 - Mahle filter
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261752 11/08/19 01:20 PM
A
atikovi Offline OP
A
So why don't they use them in brake systems? Seems like it would last forever.
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261757 11/08/19 01:23 PM
A
Anduril Offline
A
Most hydraulic systems don't reach the very high temperatures brake systems do. I'm guessing they had to change the formulation to cope with that, and put up with the water absorption as a side effect.
The convertible pump on my Mustang takes regular ATF and states it never has to be changed. As it's a closed system under absolutely no stress, I'm inclined to believe that.
2015 Nissan Versa Note 1.6/5MT
2012 Toyota Tacoma 2.7/4AT
2007 Toyota Camry 2.4/5AT
2005 Nissan XTerra 4x4 4.0/6MT
2002 Mustang GT Convertible 4.6/5MT
2009 Kawasaki Vulcan 900
2013 Hyosung ST7
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: Anduril] #5261760 11/08/19 01:28 PM
K
kschachn Online Content
Online Content
K
I don't understand the temperature thing, regardless of the temperature it still has to be exposed to some moisture for it to absorb water, right? I thought the problem with hot brake fluid is that it creates vapor bubbles which degrade the performance.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261761 11/08/19 01:28 PM
N
nthach Offline
N
Rolls-Royce/Bentley did use HSMO for their braking and suspension hydraulics. Shimano uses mineral oil for their bicycle hydraulic brakes since it's safer than glycol ether based fluids for the cyclist and environment.
I'm guessing since DOT fluid is a regulated standard and cheap as well is why mineral oil never took off for automotive brakes.
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261763 11/08/19 01:30 PM
B
Boomer Offline
B
Brake fluid is basically polyethylene oxide, a polyether. It does not interact with rubber which makes possible flexible rubber brake lines and rubber caliper/piston components in the system. I am sure the same could be done with newer elastomers today and with hydraulic fluids but there is the COST factor. The system works, why spend more??
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261764 11/08/19 01:32 PM
A
Anduril Offline
A
There is a reason, from our good friends over at the Ask Science subreddit:
Quote
"The hygroscopic nature of DOT brake fluid is actually an advantage in a major way.
So where does this water come from?
Glycol based fluids are hygroscopic which means they absorb water/moisture from the environment at normal atmospheric pressures at a rate of 2-3% per year. This process is exasperated in more humid conditions and climates.
This water content finds it's way into the brake fluid via microscopic pores in brake hoses, seals, joints and seams. As we've learnt, water mixed with DOT fluid has an adverse effect on the brake fluid by reducing it's boiling temperature and therefore reducing it's performance.
Here is how.
As water enters the system, instead of pooling in low spots (such as the calliper), due to it's weight in comparison with brake fluid, it is dispersed throughout the whole of the brake fluid. This helps to keep the boiling point of the entire brake fluid high rather than having pools of water in the system which will boil much sooner than the rest of the brake fluid.
It also prevents localized corrosion of internal parts which can be caused by water pooling in the brake system.
In some cases, Mineral oil is used in braking systems.
Unlike DOT fluid, Mineral Oil is hydrophobic and does not absorb moisture from the environment. This means that there are no wet or dry boiling temperatures to worry about, the boiling point stays constant and never drops. That's the good news.
The bad news is that any water that does enter the brake system, via seals or microscopic pores in the lines etc., will effectively reduce the boiling point of the whole brake system to that of water - just 100°C. This is because as the fluid repels any water ingress, it causes it to pool at low points within the brake system, usually the caliper, since water is heavier than brake fluid it will settle at the lowest point. This is worrying because the fluid in the caliper is more susceptible to high temperatures as it's at the business end of the brake, where the friction is created."
2013 Hyosung ST7
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: Anduril] #5261785 11/08/19 01:49 PM
K
Online Content
K
Great, thanks for the cut-and-paste. That does make some sense, at least to why it is hygroscopic.
1994 BMW 530i, 253K
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: Anduril] #5261801 11/08/19 02:10 PM
MrMoody Offline
Quote
I get exasperated with malapropisms.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: atikovi] #5261862 11/08/19 03:51 PM
P
pitzel Offline
P
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: pitzel] #5261877 11/08/19 04:10 PM
A
atikovi Offline OP
A
Originally Posted by pitzel
Yes good, if a bit dated. No mention of LV brake fluids.
Re: Does hydraulic fluid absorb moisture like brake fluid? [Re: nthach] #5262016 11/08/19 07:32 PM
P
Pelican Offline
P
Yes and if you bought it the sphere came in a Citroen box, yessiree both RR & B used Citroen suspensions (don't know about brakes though)
