replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
118 registered members (ArrestMeRedZ, andyd, Alfred_B, 2015_PSD, 1911CHAMPION, aquariuscsm, 6 invisible), 1,982 guests, and 60 spiders.
Topics306,130
Posts5,288,062
Members71,604
Odd experience - Fuel bubbling out of the tank #5261537 11/08/19 09:25 AM
M
MoneyJohn Offline OP
M
I use this gas station all the time. I never use the pumps at the very end though. There are 8 pumps and I avoid 7 and 8 because they are out of sight for the cashier so to avoid credit card fraud, I avoid using those ones.
Today though, the gas station was busy and that side freed up so I decided to fill up there. I filled up the gas without any hassle and at a click, removed the nozzle. the fuel started coming out of the tank as if someone pushing air from the bottom of the tank. The view was similar to the ones that you see at gas wells. About 4-8oz of fuel must have spilled. I have no idea what happened. Is this an issue with my car tank or the pump?
The lady before me who pumped at that pump was also wiping something there but I didn't see exactly what because another car was blocking my view. When I told the attendant, he says, I am the first person reporting. I don't remember if there was already fuel on the floor or water.
Anybody has an educated guess what must have happened here? This is the first time I experienced this. The pump handle also smelled like fuel and my hand smelled like fuel until I came home and washed. It has happened rarely with me
Re: Odd experience - Fuel bubbling out of the tank [Re: MoneyJohn] #5261664 11/08/19 11:24 AM
R
Rmay635703 Offline
R
I had splash back at one station,
Occasionally the handles and shutoff are bad.
No different than if you topped off the tank too far.
Re: Odd experience - Fuel bubbling out of the tank [Re: MoneyJohn] #5261836 11/08/19 03:14 PM
B
Blkstanger Offline
B
I'd guess bad pump handle. It's happened to me before. It let you overfill the tank.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: Odd experience - Fuel bubbling out of the tank [Re: MoneyJohn] #5261882 11/08/19 04:14 PM
B
bullwinkle Offline
B
Could have been an air pocket working it’s way out, it burps & spews gas when it happens. Sometimes filling at a lower fill rate helps.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Odd experience - Fuel bubbling out of the tank [Re: MoneyJohn] #5262323 11/09/19 07:34 AM
M
Mad_Hatter Offline
M
This has happened to me before. The pump handle is supposed to stop flow as pressure builds to a set point to prevent over filling. But if something is wrong with the pump handle or the handle doesn't create a good seal (it "thinks" there's less fuel then there actually is) then the pump can overfill.
