Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
Come on China. Let's get it right.
by Chris142 - 12/11/19 10:34 AM
'best' conventional 10w-40 pcmo for wet clutch bike
by kmrcstintn - 12/11/19 10:32 AM
Any reason not to use Carquest full synthetic?
by wbwanzer - 12/11/19 10:18 AM
53k miles on a Ford FA-1927
by BeerCan - 12/11/19 09:53 AM
Penzoil Platinum 100% Synthetic ????
by Talent_Keyhole - 12/11/19 09:50 AM
Sick and tired of these Ford (exide?) batteries
by BeerCan - 12/11/19 09:47 AM
Another motorcraft failure
by mpgo4th - 12/11/19 09:26 AM
Saw a brand new Kia Telluride yesterday.
by PimTac - 12/11/19 09:14 AM
Vintage Off Road View
by wings&wheels - 12/11/19 08:54 AM
Purolator BOSS ??
by GMguy84 - 12/11/19 08:53 AM
Recommendations for 5W-40 oil
by Rovingcowboy - 12/11/19 08:52 AM
Cool GDI deposit video
by Doublehaul - 12/11/19 08:51 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
118 registered members (69Torino, 928, alchargo, AcadiaDave, 2015_PSD, 9 invisible), 2,060 guests, and 23 spiders.
Topics298,584
Posts5,138,673
Members70,103
Most Online3,589
Nov 2nd, 2019
Page 5 of 6 1 4 5 6
Re: Filled With Wrong Oil [Re: tojo1968] #5260729 11/07/19 11:37 AM
T
tojo1968 Offline OP
T
UPDATE:
I contacted an employee that works in the service department that I have known for 5 yrs. The tech did put 5w30 in and the invoice was incorrect. As there is zero difference in performance and no additional startup or running noises, I am going to run it for 5 months until my next OC.
Thanks everyone for the input.
2016 Frontier SL Crew Cab
Re: Filled With Wrong Oil [Re: tojo1968] #5260952 11/07/19 03:39 PM
Z
zaffo757 Offline
Z
Not surprising. . Unless you have variable valve timing, it won't be an issue. Have seen many engines with VVT react badly to 30 weight oils if 20 is spec.
Re: Filled With Wrong Oil [Re: zaffo757] #5260964 11/07/19 03:47 PM
K
kschachn Offline
K
Interesting, how does it react badly?
So when the oil is cold or warming up (at least not at operating temperature) it does the same thing?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Filled With Wrong Oil [Re: kschachn] #5260972 11/07/19 04:01 PM
A
atikovi Offline
A
Just internet hearsay. Used 5W50 on a car spec'ing 5W30 with no ill effects. Better idle oil pressure when hot.
Re: Filled With Wrong Oil [Re: kschachn] #5261042 11/07/19 05:24 PM
K
ka9mnx Offline
K
VVT is electronically controlled by solenoids. They don't operate until the engine is at operating temperature.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Filled With Wrong Oil [Re: tojo1968] #5261044 11/07/19 05:25 PM
DGXR Offline
O.P., Nissan corporate may be interested to know that a dealer is using the wrong materials and saying "it's OK don't worry" when you question them.
It "may not" hurt your engine to run this interval on thinner oil viscosity, but if you do change it out, at least you will know it's running the specified oil. I don't know about anyone else but I call that peace of mind... running proper fluids in the vehicle(s) that I depend on for so many things.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Filled With Wrong Oil [Re: kschachn] #5261349 11/08/19 04:50 AM
B
billt460 Offline
B
There are threads on many of the Dodge, Ram, and Jeep forums of problems occurring with the VVT and MDS systems on 5.7 HEMI V-8's, coming from using non specified oils. Computers throwing codes, excessive "ticking", along with other issues. I'm not seeing any advantage to using thicker, non specified oils in these engines. Even if you were to get away with it, where is the supposed reward?
I live in one of the hottest cities in the nation. The Jeep dealer here puts in 5W-20 in all their 5.7 HEMI's. All year long. Summer (120F), or Winter (50F). It's much the same in Phoenix. All I've ever used is Pennzoil Platinum 5W-20 and I've never had any oil related issues.
Re: Filled With Wrong Oil [Re: ka9mnx] #5261367 11/08/19 05:20 AM
SteveSRT8 Offline
Interesting. Since the acronym VVT is many different things depending on platform/make/model, one should be careful.
Since most any model that actually moves the cam uses OIL PRESSURE to do so, then how do they function with improper viscosity every time they start up cold?
My 14 RAM 5.7 will drop to 4 cylinder operation even when first started and driven dead cold, 30W or 20W no perceptible difference. Cam rotation is not detectable except at high rpms....
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Filled With Wrong Oil [Re: tojo1968] #5261371 11/08/19 05:26 AM
B
billt460 Offline
B
One of the biggest issues to pop up from using heavier viscosity oils in these engines, (5.7 HEMI V-8), is the P1521 Code. Basically caused by using incorrect viscosity engine oil.........
P1521–INCORRECT ENGINE OIL TYPE
•When Monitored: Engine Running.
•Set Condition: Using the oil pressure, oil temperature and other vital engine inputs the PCM can determine the engine oil viscosity. Incorrect viscosity will effect the operation of the MDS by delaying cylinder activation.
Possible Causes INCORRECT ENGINE OIL TYPE ENGINE OIL CONTAMINATION ENGINE OIL
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Diagnostic Test
1. ACTIVE DTC
NOTE: Review the customers oil change history. Ensure the customers is using the correct engine oil viscosity. If the incorrect oil is being used, change the oil, using the correct engine oil viscosity.
Re: Filled With Wrong Oil [Re: atikovi] #5261704 11/08/19 11:19 AM
Z
zaffo757 Offline
Z
Um...OK. There are some systems like the Ford used on the Duratech that will act up with heavier oil. It needs 5W20. Not heresay or conhjectur. If you engine acts up, change the oil. Don't; just dumb a$$ your way through it.
Re: Filled With Wrong Oil [Re: zaffo757] #5261710 11/08/19 11:23 AM
demarpaint Offline
Are you saying these Duratech engines will "act up" running on 0W30 or 5W30 oil? I have my doubts.
God Bless Our Troops
Re: Filled With Wrong Oil [Re: demarpaint] #5261716 11/08/19 11:29 AM
Z
zaffo757 Offline
Z
Are you saying these Duratech engines will "act up" running on 0W30 or 5W30 oil? I have my doubts. [/quote]
Yes. My mother's Mazda CX9 with a 3.7 FORD Duratech and several other Explorers near me with VVT experienced "no valve timing advance"
conditions with 10W & 5W/30 from quick lube places. I told them to read the oil cap and the manual.
Fluid - 5w20 / 0W20 fixed. The tolerances are very tight. Just cause BMW sells 5W60 does not mean you can put it in all cars and it will be OK.
Specs matter.
Re: Filled With Wrong Oil [Re: zaffo757] #5261720 11/08/19 11:35 AM
A
atikovi Offline
A
GM 3.6L with over 150K. Oil gauge read on the low side though no light on. Nothing actually wrong, just don't like seeing the gauge so low. 5W50 took care of it will no ill effects.
Re: Filled With Wrong Oil [Re: zaffo757] #5261722 11/08/19 11:36 AM
A
atikovi Offline
A
HMM, maybe this summer.
Re: Filled With Wrong Oil [Re: atikovi] #5261846 11/08/19 02:25 PM
Z
zaffo757 Offline
Z
GM 3.6L with over 150K. Oil gauge read on the low side though no light on. Nothing actually wrong, just don't like seeing the gauge so low. 5W50 took care of it will no ill effects.[/quote]
Amen to that! I had a 69 Mustang with over 150k miles and the mains had so much slop the crank would slam around till the oil pressure came up with 10w30. Moved to straight 30 and 40 as the miles added up.
A cut out switch for the coil allowed me to crank for 5-10 seconds or so to get the oil moving before hitting the "CONTACT" switch and blammo! Off she went.
Many engines can run on about anything from the discount store...these new fangled things...not so much.
Page 5 of 6 1 4 5 6
