List Impossible Sparkplug Replacement
by borgward - 06/04/20 01:31 PM
BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
85 registered members (14Accent, 4WD, ABN_CBT_ENGR, 2015_PSD, 53' Stude, 9 invisible), 2,059 guests, and 79 spiders.
Topics306,136
Posts5,288,143
Members71,604
World's largest welding rod. #5261250 11/07/19 10:52 PM
T
tig1 Offline OP
T
Many years ago I welded with 7024 drag (jet rods) rods that were 36 inches long on cargo ships.
https://www.facebook.com/watch/?v=457755075097595
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: World's largest welding rod. [Re: tig1] #5261257 11/07/19 11:04 PM
I
irv Offline
I
Originally Posted by tig1
Many years ago I welded with 2021 drag rods that were 36 inches long on cargo ships.
I have only welded with 7018 and 6013 welding rods. I had no idea welding rods were as long as 36" inches let alone 4 footers! crzy
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: World's largest welding rod. [Re: irv] #5261262 11/07/19 11:16 PM
T
tig1 Offline OP
T
My bad. They were 7024 rods.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: World's largest welding rod. [Re: tig1] #5261327 11/08/19 03:27 AM
B
billt460 Offline
B
That's not a puddle, it's a lake!
Re: World's largest welding rod. [Re: tig1] #5261353 11/08/19 06:00 AM
N
Neely97 Offline
N
Electrode Envie !
Re: World's largest welding rod. [Re: tig1] #5261568 11/08/19 09:46 AM
SOHCman Offline
Simply shocking!
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: World's largest welding rod. [Re: tig1] #5261987 11/08/19 07:02 PM
spk2000 Offline
Steel mill I used to work for used 36 inch wide electrodes that were 20 feet long and would screw together to melt the scrap steel into a 300 ton puddle. This was called an EAF or electric arc furnace if your interested enough to look it up.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: World's largest welding rod. [Re: tig1] #5262055 11/08/19 08:26 PM
dlundblad Offline
Holy smokes.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: World's largest welding rod. [Re: spk2000] #5262065 11/08/19 08:33 PM
J
JTK Offline
J
EAFs are impressive and frightening!
Arcing and sparking all around. It's been years for me, but I used to help run/service onsite oxygen plants at steel mills, etc.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: World's largest welding rod. [Re: tig1] #5262157 11/08/19 10:16 PM
tom slick Offline
You could weld the crack of dawn with an electrode that large!
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: World's largest welding rod. [Re: tig1] #5262169 11/08/19 10:44 PM
spasm3 Offline
Wow! Its still red while they were chipping away the slag!
I'm surprised a regular welding helmet is enough, could you even use auto darkening or would the brief flash be too much? Has to be a lot of UV coming off that rod.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: World's largest welding rod. [Re: spasm3] #5262185 11/08/19 11:07 PM
A
AndyB Offline
A
Thinking the filter shade has to be a 12.
Re: World's largest welding rod. [Re: JTK] #5262341 11/09/19 08:14 AM
B
billt460 Offline
B
EAFs are impressive and frightening! Arcing and sparking all around. It's been years for me, but I used to help run/service onsite oxygen plants at steel mills, etc.
I remember when I was an apprentice, our class took a tour of Finkl Steel in Chicago. They had a huge carbon arc furnace they melted scrap in. They were just finishing loading it when we showed up.
The guy giving the tour said we would stay to watch the initial start up, it would be worth it. They loaded just about everything into that heat. From old engine blocks to just about any type of scrap you could think of.
When they finally cranked it up there was a loud crackling roar, and you could hear big pieces and whole engine blocks banging around inside. He told us the amount of electric it consumed, but I can't remember what it was. He did say it was so much that in the Summer they only ran it at night, because it was much more cost effective. This was back in the early 70's.
In the Summer it got so hot in the place, that the guys running the open die forging presses could go home without an excuse if the outside temperature was over 90F.
Re: World's largest welding rod. [Re: spasm3] #5262373 11/09/19 09:24 AM
tom slick Offline
The shade isn’t what protects from UV and IR even clear plastic protects from UV and IR. The shade is for comfort and to see the work clearly.
Re: World's largest welding rod. [Re: tom slick] #5265260 11/12/19 05:42 PM
T
tig1 Offline OP
T
For comfort? I guess like keeping your eyes from the flashes.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
