BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
91 registered members (4WD, 14Accent, 77GrandPrix, ABN_CBT_ENGR, amblerman, 9 invisible), 2,092 guests, and 81 spiders.
Topics306,135
Posts5,288,105
Members71,604
HP Envy 15 laptop weak wifi upgrade #5261203 11/07/19 09:40 PM
K
KrisZ Offline OP
K
Just wanted to share this simple upgrade with anyone that has an HP laptop and experiences a weak or intermittent wifi signal. Ours would even completely disconnect while being quite close to the router. It was very erratic.
Not all wifi cards will work so you have to do some research. For our Envy 15 model the intel Dual Band wireless AC-7260 works. Make sure to get model 7260HMV that is 867Mbps instead of 300. I got it for around $25 on Amazon.
Laptop model in question is 15-q258ca, but this should be good for other envy models too.
Now the signal is nice and strong even though the location has not changed
The picture is of the new card I got.
[Linked Image]
2015 Grand Caravan 3.6L - 35k miles.
2006 Mazda 3 2.0L - 186k miles
Re: HP Envy 15 laptop weak wifi upgrade [Re: KrisZ] #5261550 11/08/19 09:35 AM
stockrex Offline
I have 2 new hp laptops I bought from costco with the intermittent disconnect issue,
The problem is software/firmware related, I got used it.
I have the same problem in my lenovo thinkpad,
good solution to swap out the wifi card,
post a part # if you can, that will help us get the correct item.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: HP Envy 15 laptop weak wifi upgrade [Re: KrisZ] #5261559 11/08/19 09:40 AM
Quattro Pete Offline
Nice upgrade.
The internal wifi card in my Lenovo X230 could only support 2.4 GHz spectrum. I swapped it out for an upgraded Intel card that supported 5 GHz as well. Alas, there was some slight incompatibility issue that would cause my audio to glitch/stutter when I was transferring data over wifi. I finally ended up getting an external USB wifi adapter. No more interference with audio, and I get even higher transfer speeds now.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: HP Envy 15 laptop weak wifi upgrade [Re: Quattro Pete] #5261603 11/08/19 10:14 AM
K
KrisZ Offline OP
K
I highly doubt it's the software. My HP was doing it from the start as well and even after several driver updates. The card was a generic Broadcom wifi card with HP specific part numbers on it. I think it is simply a matter of cheap hardware.
Regarding part numbers, I don't see any, that is why I posted a pic of the card. It only shows model number, which is: Intel 7260 HMV.
Originally Posted by Quattro Pete
Nice upgrade.
Yes, my HP laptop was also 2.4 GHz and it would've been fine if the signal was consistent and strong.
This new Intel card also had some issues. It worked normally on the drivers windows initially got. However after I manually undated the drivers, the 5GHz band would not work properly. It would connect, but the status would say "No Internet Connection". I then downloaded the latest driver from Intel, just to make sure and the same thing happened.
I had to uninstall the drivers and force windows to install the old ones it did when I first installed the card. The card works fine now on the drivers from 2015, go figure LOL.
