Forums Migration
Please read this thread
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
108 registered members (2003f7, 2009Edge, 55hambone, 2015_PSD, 2004tdigls, 2010Civic, 11 invisible), 1,983 guests, and 21 spiders.
Topics307,566
Posts5,313,248
Members71,876
Shuddering during acceleration #5261192 11/07/19 09:33 PM
P
powersmo Offline OP
P
I'm driving a 2012 Honda Accord SE that shudders during acceleration. The acceleration is smooth until I get to 20 mph and then it has a light shuddering until I hit 30 mph. That is the only time it occurs. It had been going on for a few months and I recently though that when it was time to replace my tires it would be taken care of. Nope, still happens after new tires were installed by Discount Tires. Would appreciate your suggestions on what to do.
Re: Shuddering during acceleration [Re: powersmo] #5261199 11/07/19 09:38 PM
J
JLTD Offline
J
Fresh transmission fluid would be my first thought. Sounds like it may be having trou le going into lockup?
Lates.
Re: Shuddering during acceleration [Re: powersmo] #5261206 11/07/19 09:44 PM
double vanos Offline
Maybe lube guard would help. How many miles?
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Shuddering during acceleration [Re: powersmo] #5261210 11/07/19 09:53 PM
G
gregk24 Offline
G
I am guessing it is a V6? I would do 3 drain and fills on the transmission with DW-1 (Honda OEM) fluid. Hopefully that will clear it up.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Shuddering during acceleration [Re: powersmo] #5261218 11/07/19 10:07 PM
N
NormanBuntz Offline
N
Check to see if there is a Honda service bulletin for your car. There was one on my 2013 Accord involving replacing the CVT valve and reprogramming the ECU. Does your OM recommend CVT fluid changes every 30K miles?
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 13K, 2nd owner
2007 Honda Ridgeline RTS, 98K, original owner
2007 Infiniti M35, 116K, original owner
Re: Shuddering during acceleration [Re: NormanBuntz] #5261230 11/07/19 10:20 PM
slacktide_bitog Offline
The 2012 Accord doesn't have a CVT. That didn't come until 2013 with the next generation smile
Either way, transmission fluid changes are suggested by the MM
Re: Shuddering during acceleration [Re: powersmo] #5261253 11/07/19 10:59 PM
T
tcp71 Offline
T
Misfires can show up as shuddering as well. If you can scan for them or change plugs/ coils.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Shuddering during acceleration [Re: powersmo] #5261267 11/07/19 11:25 PM
G
GMBoy Offline
G
I would be looking at misfire (plugs or coils) and a transmission fluid service using Honda fluid or Valvoline MaxLife.
Re: Shuddering during acceleration [Re: gregk24] #5261358 11/08/19 06:07 AM
discountdon Offline
+1 on Lubegard Red or Lubegard's Dr. Tranny Instant Shudder Fixx
or more!
No more shudder for me after Sea Foam Trans Tune with multiple drain and fills before (due to dirty ATF fluid) and during treatment spaced apart:
https://www.bobistheoilguy.com/foru...onda-5-speed-automatic-trans#Post5252440
Valvoline Import ATF +SEAFOAM TRANSTUNE | 5W-20 +AUTO RX PLUS
sailing 3rd party additives are the elixir to driveline immortality
planned obsolescence WWFis traitorous to the world
Re: Shuddering during acceleration [Re: powersmo] #5261419 11/08/19 07:50 AM
DriveHard Offline
if it is near the tire rotation frequency, it could be a bad CV joint
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
