Do You Fly the BITOG Flag?
by ARCOgraphite - 11/13/19 08:42 AM
Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
108 registered members (AndyB, 2004tdigls, 1978elcamino, 64bawagon, Andrei, andyd, 8 invisible), 2,074 guests, and 20 spiders.
Topics297,342
Posts5,113,591
Members69,842
Most Online3,589
Nov 2nd, 2019
Convert B&S Engine to Self Propelled? #5261181 11/07/19 08:17 PM
M
Miller88 Online Content OP
OP Online Content
M
My free mower saga continues. I swapped engines over the summer and got the mower running good!
About a month ago, I decided to run the rotted out deck mower and the bad engine up to the recycle pile at the dump. The next day I managed to drive over the good mower with my pickup (long story). It's mangled pretty good and I probably could have salvaged parts off of the one I threw out to make it work. That's what I get for de-hoarding.
So I was given a Murry self propelled mower. It, too, has the same Briggs 675 190CC engine. It has no spark. Rather than checking the coil and figuring out why it doesn't work I was going to swap the engine. But it appears the bottom of the crank may be different? It doesn't appear to be some sort of keyway I can change. Unless i'm missing something.
Is this even possible? Or should I start playing swaptronics with the coil and shroud from the crushed mower.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5261225 11/07/19 09:18 PM
R
Rand Offline
R
Dumb stuff happens, I was putting the winter tire set away from the 2010 accent and somehow I left the sockets(2) and lug nuts on the trunk in a box and drove off.. never found them again.
I'd probably just start over with a clearance mower or craigslist cheapie.
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5261255 11/07/19 10:00 PM
V
vw7674 Offline
V
If you have the 'stubby shaft' PTO remaining, you would resort to a crankshaft swap between the two to get that extra key way to drive a self-propel pulley.
Time consuming yes but self-propel is my favorite push mower feature.
Do it & save any spares you salvage, junk the rest........again. Most of the newer engines have that extra keyway. : (
Re: Convert B&S Engine to Self Propelled? [Re: Rand] #5261357 11/08/19 05:06 AM
L
Lubener Offline
L
So that's where those came from.
The "thinking" man's friend.
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5261417 11/08/19 06:48 AM
Z
ZebRuaj Offline
Z
It may work as long as the blade adapter swaps over and snugs up. But if your location is like mines, just keep an eye on the free classifieds and something will pop up. I told myself I was done hoarding when the leaves fell, but I've been finding freebie Toro's almost every other day.
~Shade tree mechanic for friends and family.
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5261498 11/08/19 07:57 AM
M
OP Online Content
M
I could just swap the other engine and not use the self propelled. Not that it's something I would use anyway. The blade adapter and pulley for the front drive doesn't seem to come off. I tried to get it off. So looks like it may be a unique crankshaft.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5261927 11/08/19 04:19 PM
V
vw7674 Offline
V
There should be a set screw on the thicker part of the engine pulley. They tend to lock in place after a few years.
And finding another engine (as mentioned above) would be easier than a crank swap I mentioned earlier.
Re: Convert B&S Engine to Self Propelled? [Re: Miller88] #5262130 11/08/19 08:39 PM
M
mk378 Online Content
Online Content
M
It's not a special crankshaft. There's no way the engine could be put together if it were a permanent part. Like @vw7674 said, the blade adapter is supposed to come off, but they often get hopelessly rusted in place.
