BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
87 registered members (14Accent, 4WD, Anduril, AndyB, 77GrandPrix, 8 invisible), 2,041 guests, and 78 spiders.
Topics306,135
Posts5,288,107
Members71,604
2012 GMC Terrain 3.0L V6 Spark Plug Change #5260976 11/07/19 05:06 PM
B
benjamming Offline OP
B
2012 GMC Terrain 3.0L SLE VIN 5 (Flex) 200k miles
I assume that I really need/have to remove the intake manifold when replacing the (rear) spark plugs. Which I would assume means replacing the gasket(s). Would that mean replacing both the upper & lower gaskets? Throttle body gasket as well while doing this job to clean it? Using iridium plugs AC Delco 41-109. First time for me to work on this vehicle so appreciate any insight.
Thank you.
'16 Toyota Highlander 2GRFE/U660F
'02 Honda Accord J30A1/B7XA
'01 Ford Ranger 4.0L/5R55E
'94 Pontiac Grand Am 3.1L/4T60E
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5261004 11/07/19 05:29 PM
N
nascarnation Offline
N
I saw a post on the TerrainForum.net that mentioned you can get 4 plugs out w/o removing the manifold and another one almost out but the last one requires the removal. Sometimes you can get by w/o replacing gaskets but I think it's good practice to do that anyway.
200,000 on a set of plugs is pretty darn good. I did my Caddy 3.6 at about 80,000 and they didn't really look too bad but I figured with my mileage accumulation pattern, and chassis rust, that was likely halfway to the scrappage time for the car.
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5261189 11/07/19 09:31 PM
M
Matt1980 Offline
M
Check out this video on youtube
https://www.youtube.com/watch?v=nGONpPQl1P4
Doesn't look terribly difficult. you do have to remove the intake manifold, but it looks like you only have to replace the lower gasket, and that is only if you really want to. I would do it though, Since the gasket is only like $20.
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5261197 11/07/19 09:36 PM
slacktide_bitog Online Content
Online Content
Yes, get new gaskets for the intake manifold, as well as valve cover gaskets. You might as well do that while you're in there. Replace every gasket you have to remove!
You should use NGK's new ruthenium spark pugs. Part #91276. They will last even longer than iridium, so you will NEVER have to pull the intake again! happy
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5263412 11/10/19 03:53 PM
B
B
Thank you all for the input. I plan on doing it next weekend. BTW, it's my sister's vehicle so work will occur away from home.
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5263421 11/10/19 04:07 PM
clinebarger Online Content
Online Content
You just need the Upper Plenum Gasket. This is a easy straight forward job. Plenum bolts call for 17 ft lbs.
2001 Chevy Camaro L92/4L80E
Re: 2012 GMC Terrain 3.0L V6 Spark Plug Change [Re: benjamming] #5271810 11/19/19 01:45 PM
B
B
Oil was in the spark plug wells. I assume that means a valve cover gasket kit is required with new spark plug tube seals?
