Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Snow Shovel Recommendations ?
by Dwight_Frye - 11/21/19 01:29 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
82 registered members (69GTX, Aero540T, 2015_PSD, 4WD, agpatel, 5 invisible), 1,619 guests, and 23 spiders.
Topics297,752
Posts5,121,884
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 1 of 3 1 2 3
Jatco CVT with a chain #5260718 11/07/19 11:28 AM
J
JTK Offline OP
J
Apparently Jatco has gone with a chain as opposed to their typical belt on some of the JF017E units used with VQ35 engines. I didn't know this. Sorry if it's been posted.
[Linked Image from sc02.alicdn.com]
[Linked Image from sc01.alicdn.com]
[Linked Image from machineryoffers.com]
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Jatco CVT with a chain [Re: JTK] #5260728 11/07/19 11:36 AM
B
benjy Offline
B
no matter! i will NEVER own or recommend a CVT. for me its a 3 pedal affair or NO sale!
Re: Jatco CVT with a chain [Re: benjy] #5260748 11/07/19 11:54 AM
J
jbutch Offline
J
Unfortunately, it's only a matter of timer until the MT goes the way of the dodo.
2015 Forester XT @ 100k km
Current fill: Rotella T6 Multi Vehicle 5w-30 with Fram Ultra XG7317
Re: Jatco CVT with a chain [Re: JTK] #5260899 11/07/19 02:30 PM
J
JTK Offline OP
J
Just to add to the above. The chain has been used since the 2013 Pathfinder came out, thus the 5000lb towing capacity of the 2013-2016 model years and 6000lb for the 2017+. 2017+ got the extra 1000lbs due to the direct injected engine.
Re: Jatco CVT with a chain [Re: JTK] #5260920 11/07/19 02:58 PM
M
Miller88 Offline
M
Do the pathfinders suffer from the chronic CVT problems that the rest of the lineup does?
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Jatco CVT with a chain [Re: Miller88] #5260923 11/07/19 03:04 PM
J
JTK Offline OP
J
From a fella on the Pathfindertalk site:
"This issue has never been the belt/chain, its the pressure control valve in the CVT Oil Pump, which regulates the flow of CVT fluid contracting and expanding the pulleys that the chain is attached to.
The Valve is made out of aluminium and scores easily and sometimes even seizes due to wear from metal particles in the CVT fluid, which then creates the domino effect, pulleys to expend contract correctly, chain slips and bounces, creates more wear with metal particles entering the cvt fluid and gradually it gets worse and worse.
There are after market valves which are made from titanium, to fix this, but you need to basically tear down the whole CVT to replace this $20 part. Hence why Nissan did F.. All about it. There has been new oil pumps designed, to do away with the pressure control valve altogether, and suspect these are in the newer builds, like 17 onwards as this pump was late 2016 design.
It's anyones guess if Nissan started updating the pumps in the reman CVTs for the ones prior to this or if they even used titanium valves, guess we won't know unless they disclose it."
Re: Jatco CVT with a chain [Re: JTK] #5260932 11/07/19 03:16 PM
M
Miller88 Offline
M
I saw one video online where someone dissected a failed CVT out of an older rogue and , while the metal belt failed, it was determined that it was small ball bearings inside the pump that failed. Could be similar.
But it's definitely not a change made to the smaller units right? I really could see myself picking up a mirage with a CVT or a Versa note with a CVT as a small DD / runabout vehicle. I just wouldn't want to have to scrap the thing with a $7000 CVT fails.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Jatco CVT with a chain [Re: JTK] #5260933 11/07/19 03:21 PM
J
JTK Offline OP
J
I think that's how it goes with this. It's not the belt or chain that fails, it's other components that cause a fluid pressure loss, which causes slack in the belt, then more wear.. until it snowballs to the point of failure. I feel that fluid changes early on and then done regularly help the above, but then you hear of units going 200K miles with no fluid changes. As much as I don't mind CVTs, I'd avoid a Versa with one. You don't seem to hear of issues with CVT powered Mirages, but there's so few of them out there compared to Nissans.
Re: Jatco CVT with a chain [Re: benjy] #5260934 11/07/19 03:21 PM
A
AC1DD Offline
A
Yep, same here. I'll never buy anything but manual transmission vehicles new.
For those that are too lazy to drive a stick they should buy a traditional geared automatic box, NEVER a CVT.
Re: Jatco CVT with a chain [Re: AC1DD] #5260935 11/07/19 03:23 PM
J
JTK Offline OP
J
^ There he is! thumbsup
Re: Jatco CVT with a chain [Re: jbutch] #5260989 11/07/19 04:17 PM
N
nascarnation Offline
N
The US military decided back in the early 80s that it was a huge waste of resources training recruits to drive manuals.
Also that some of the women coming in were smaller and struggled with the force and reach of a truck clutch pedal.
So we've sold a LOT of Allisons to them in the years since.
Re: Jatco CVT with a chain [Re: nascarnation] #5260999 11/07/19 04:22 PM
J
JTK Offline OP
J
Yep, the higher ups at work haven't ordered a new over the road tractor without automatic in a few years now. I'm not sure if it's a cost, personnel or fuel savings thing? I know the truck drivers hate them. They buy mostly bottom of the barrel Freightshakers with the 10spd auto.
Re: Jatco CVT with a chain [Re: JTK] #5261011 11/07/19 04:41 PM
B
bbhero Offline
B
Huh... Interesting... Wonder what belt my car came with being it is a 08 VQ??
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Jatco CVT with a chain [Re: AC1DD] #5261066 11/07/19 05:50 PM
Driz Offline
BINGO!
Re: Jatco CVT with a chain [Re: JTK] #5261224 11/07/19 09:18 PM
M
Miller88 Offline
M
I think it's hard to kill any tansmission with 73 horsepower!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Page 1 of 3 1 2 3
