how to deep clean calipers? baked on brake dust
Corona, CA
calipers not attached. these are toyota calipers. is there a coating on the calipers or is it raw cast metal? i have used a stainless wire brush, gunk engine foaming degreaser, and brake parts cleaner, and simple green. cant get the baked on brake dust in the inside calipers. they are not from the rust belt so no rust at all. are there other solvents i could try? i want to clean as much as i can before taking out the pistons to rebuild.
Meguiar's Ultimate Wheel Cleaner and elbow grease.
Since you're doing a rebuild, maybe a dunk in Chemtool is in order?
Originally Posted by Railrust
Sand blast them.
My thoughts exactly.
Media blast or hot-tank. If you can get the old school Chemdip that smells like death and will dissolve anything non-metallic that can work as well.
Some motorcycle wrenches even use Lestoil to soak parts, which is the same thing as Pine-Sol before it was reformulated to not have pine oil or solvents.
