Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
102 registered members (92saturnsl2, 53' Stude, 1foxracing, 2010Civic, 1978elcamino, aircooled, 4 invisible), 2,072 guests, and 27 spiders.
Topics297,341
Posts5,113,567
Members69,842
Most Online3,589
Nov 2nd, 2019
Brake fluid flush-best way #5260633 11/07/19 09:35 AM
R
rekit Offline OP
R
Last time I did this the recommended way (flush thru the system starting furthest wheel from MC) that brake began leaking a week later. All the heavy crud went into the slave cylinder and settled there (drum brake) damaging the rubber. I was young and this was the first time I did this procedure.I was PO-ed since there I was trying to prevent exactly what I just caused! I guess best practice would be to rebuild the cylinders after a flush or ?
Re: Brake fluid flush-best way [Re: rekit] #5260643 11/07/19 09:49 AM
N
NoNameJoe Offline
N
If your system has "heavy crud" in it, this would have happened anyway wouldn't it?
I don't think you can rationally say you always have to rebuild wheel cylinders after a flush. If the fluid is in good condition and you do the fluid change properly, you likely won't run into an issue.
2015 Civic LX Coupe
Re: Brake fluid flush-best way [Re: rekit] #5260655 11/07/19 10:05 AM
R
rekit Offline OP
R
Probably, but maybe the crud was "happy" where it was until I moved it all to that wheel. Anyway, lesson learned. I wonder if the brake shop does it differently?
Re: Brake fluid flush-best way [Re: rekit] #5260662 11/07/19 10:08 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
One trick I use during a caliper rebuild is to butter the caliper bore surface with silicone paste. Then pack more silicone inside the dust boot. This helps keep the corrosive environment out of the critical areas while allowing movement of the piston.
Re: Brake fluid flush-best way [Re: rekit] #5260791 11/07/19 12:35 PM
W
WhyMe Offline
W
i have both a motive and vaccum bleeder. much prefer the vacuum bleeder. i do it when rotating tires. put car on stands remove all the wheels . suck out fluid from the master cylinder and replace with fresh. then go to each wheel and vac out the old fluid till its comes out clear. be sure to keep the master full after each wheel.
this is a good tool but needs air. https://www.harborfreight.com/brake-fluid-bleeder-92924.html?_br_psugg_q=brake+bleeder
Re: Brake fluid flush-best way [Re: rekit] #5260853 11/07/19 01:28 PM
R
rekit Offline OP
R
Thanks. I'm always looking for a reason to go to HF (especially if they're "having a sale") lol. So I'll get one of those or similar, flush, and rebuild the rears. BTW brakes are working perfect now.
Re: Brake fluid flush-best way [Re: rekit] #5260875 11/07/19 01:55 PM
W
WhyMe Offline
W
there is always a 20% off coupon online for HF. just search for it
Re: Brake fluid flush-best way [Re: rekit] #5260938 11/07/19 03:24 PM
Z
zaffo757 Offline
Z
I find replacing the stock bleeder valves with speed-bleeders (has spring loaded check valve) makes is so easy it hardly qualifies as work. Just get 2 qts of fluid, crack and pump all 4. Easy.
