It really depends on your clearances. If you have an old school forged piston small block with,005 to ,007 piston clearance, .0015 to .0025 main clearance and .0025 to .0035 rod clearance like back in the day 40 years ago then 20w50 is a good choice. Modern engines are made much tighter. You can run into a situation where there is sufficient throwoff to keep the cam lubed in cold weather with tighter modern clearances.
Rod
