Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
Mercedes coolant mixed
by Rohan - 11/14/19 12:49 PM
Lady takes her oil seriously
by Marco620 - 11/14/19 12:25 PM
Bypass oil filter problem
by mario49 - 11/14/19 12:14 PM
2001 Toyota Sequoia
by Tlhfirelion - 11/14/19 11:02 AM
Creation date
by Duffyjr - 11/14/19 10:36 AM
Rescuing a critically sluged 6.4 F-350
by NDServices - 11/14/19 10:02 AM
New Fram boxes
by FordBroncoVWJeta - 11/14/19 10:00 AM
My dad bought a 2017 F150.
by dan_erickson - 11/14/19 09:52 AM
You ever spray paint inside the house?
by atikovi - 11/14/19 09:48 AM
recent experience with Adv Auto
by windeye - 11/14/19 08:59 AM
Lifted Trucks
by Passport1 - 11/14/19 08:56 AM
Fleet oil intervals to save money?
by Todd00000 - 11/14/19 08:44 AM
Motive power brake bleeder
by Redright9 - 11/14/19 08:25 AM
*GRAPHENE* a new oil-additive????
by cadchris - 11/14/19 08:21 AM
contraption22, Caydel, Bull58, Koncrete_Cam, DirtyTony
69863 Registered Users
125 registered members (53' Stude, 28oz, 2015_PSD, Al, 2003f7, Aichiguy, 8 invisible), 2,084 guests, and 26 spiders.
Topics297,414
Posts5,115,057
Members69,863
Most Online3,589
Nov 2nd, 2019
What can cause this type of HID failure? #5260549 11/07/19 08:17 AM
cwilliamsws6 Offline OP
One of my 8000K HIDs has been looking yellow for awhile now so I finally swapped them for LEDs.
Upon closer inspection, the "bad" bulb looks like it has glaucoma compared to the "good" bulb.
Just curious what could have made this happen. Bulbs were about 2.5 years old.
Image link because for some reason the tag won't work:
https://preview.redd.it/zrf5l2vk27x...95238bf287ad87c57ac35b749a8d8afee39be314
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
Carquest conventional 5W-20, Carquest Premium 84356 filter
"Bad decisions make good stories."
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260576 11/07/19 08:49 AM
B
BMWTurboDzl Offline
B
Repeated on-off cycling? Does your vehicle have the "auto" feature?
435i
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260589 11/07/19 09:00 AM
No it does not. I also had pulled the fuse for the DRL because supposedly my car flashes the lights super fast to give the appearance it's running at half power.
So they're either on, or they're not.
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260626 11/07/19 09:30 AM
P
Petabytes Offline
P
For my several years of HID experience, when the HID bulb going yellow. It would die soon. Seems the quality and the duration of the HID bulb is not as good as several years before. I was needed to have replace several sets even from different local stores. Had to replace more frequently.
If it's no name brand bulbs, the quality is no difference from bought at local store, eBay or Amazon. Depending on the QC and the production batch of the factory.
Just got a cheap $20 / pair from Amazon but the quality and color was much better than a $80 / pair from a local store.
Also the color is not the same too even from the same source.
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260632 11/07/19 09:34 AM
E
edyvw Offline
E
If it is not Osram or Phillips it is not going into my car.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260634 11/07/19 09:35 AM
U
Ursatdx Offline
U
China.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260740 11/07/19 11:47 AM
N
nthach Offline
N
Those look like rebased Chinesium HIDs which I don't trust nor recommend. Regardless, a new HID bulb is nearly clear but you can see the metal salts(the halides that are responsible for the gas plasma inside of an HID capsule) if you look closely. The metal electrodes do get eroded and eventually there's not enough metal to create the arc. That's failure mode of an HID, the cloudiness is the vaporized remains of the capsule electrodes and whatever is left of the metal salts.
All HID bulbs work on the same principle - the ballast generates the high voltage needed to start an arc at the capsule electrodes in order to vaporize the metal salts(or vaporized mercury/sodium) in the capsule. It's all just ions working to give off light.
Re: What can cause this type of HID failure? [Re: cwilliamsws6] #5260784 11/07/19 12:29 PM
Dave9 Offline
8000K HIDs? Good grief, I don't want anyone on the road with those blue blinding atrocities.
Every vehicle that has them should be stopped, driver ticketed, vehicle impounded, registration revoked until an inspection shows the problem was rectified.
Re: What can cause this type of HID failure? [Re: Dave9] #5261717 11/08/19 11:30 AM
E
edyvw Offline
E
It is amazing what kind of LED stuff people put on, especially on JEEP's and pick-up trucks.
Worst thing is they blind others and still do not provide visibility of OE stuff.
