Forums Migration
Please read this thread
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
103 registered members (2015_PSD, aquariuscsm, 2003f7, 2009Edge, alarmguy, 14 invisible), 1,957 guests, and 27 spiders.
Topics307,570
Posts5,313,276
Members71,876
2003 Golf TDI 11.2K miles - RLI Biosyn 10w40 UOA #5260406 11/07/19 03:02 AM
CleverUserName Offline OP
I got this car last year to replace my '09 Jetta TDI which VW bought back. I got if from the second owner who had all maintenance records.
2003 Golf TDI 5MT
178.5K miles
Malone Stage II tune w/ Bosio PP520 Nozzles
Car also has SMF conversion and SB stage II clutch.
Sport suspension w/ Koni struts, not lowered though.
Driven spiritedly when warmed up. Car makes light smoke @ 3,000+ RPM
EGR is intact and functional, however turned down to minimum setting by adaptation in VCDS.
Avg. lifetime MPG is 44.6 hand calculated on Fuelly app.
Fuel additive is Amalgamated TDR-FL dosed @ 10 ml/Gallon of fuel https://www.amalgamatedinc.com/tdr-fl.aspx
-Oil was in the sump for a year and 11.2K miles
-Bosch Premium 3977 (Made in China) Filter
-Oil was RLI Biosyn HD Low Ash 10w40 (10w30 and 15w40 blend)
-Analysis includes VOA baseline
-Sample was pulled with sample pump while car was hot and running.
Even though the TBN is still there it appears to have thickened up. Early signs of oxidation?
Wear is low except for LEAD. Not sure why...
Also ran this 10w40 oil in my 2.8 Duramax and it did great @ 8k miles. Maybe 11K is too much for Biosysn.
4.8 qt sump, one qt oil added
Manganese and LOW SOOT @ 0.2%. This is from the TDR-FL additive which I believe contains MMT. This stuff works great at increasing combustion efficiency, it has reduced measurable soot in my last two UOAs by almost 75%. It takes about 5K miles before the oil will begin to get dark when using TDR-FL. Can't say enough good things about this stuff because it actually works!
[Linked Image from i.imgur.com]
Re: 2003 Golf TDI 11.2K miles - RLI Biosyn 10w40 UOA [Re: CleverUserName] #5271240 11/18/19 08:52 PM
J
jayg Offline
J
I may have missed it but did you put this oil in the car or did the previous owner before you bought it? The Restore compression restore additives have lead in them and I've seen people add it to the oil and skew their lead numbers. I used leaded race fuel in my Datsun exclusively and when my carburetors needed a rebuild, the lead was showing up in UOAs.
I'd change it and run it another year at that annual mileage and then see how it looks.
2019 Toyota Prius E-AWD- TGMO 0w16
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
...and a bunch of old motorcycles
