BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
95 registered members (4WD, Anduril, 14Accent, 77GrandPrix, ABN_CBT_ENGR, amblerman, 7 invisible), 2,101 guests, and 72 spiders.
Topics306,134
Posts5,288,099
Members71,604
ATF fluid life sitting in cold garage #5260245 11/06/19 08:46 PM
SouthDakotaDad Offline OP
I found a case of Toyota WS fluid from a different vehicle I had sold. I recently bought a Scion xB and it uses WS fluid.
This case has been sitting in my garage for two years in 90 degree heat down to 0F here in South Dakota.
Should I use the fluid given the severe temp extremes and how long it has been sitting?
Thanks for the replies.
2015 Corolla LE, 1.8, QSUD 0w-20, Fram Ultra, 55K miles
2012 Scion XB 2.4, QSUD 0w-20, Fram Ultra, 21K miles
2017 Mitsubishi Outlander Sport--Can't wait to get rid of it
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260247 11/06/19 08:48 PM
rooflessVW Offline
Well.
If it was in your transmission for two years you wouldn't second guess it, would you?
"Zed's dead baby, Zed's dead."
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260248 11/06/19 08:48 PM
J
JustinH Offline
J
No problem I'd run it.
'16 Ford Escape
'11 Scion XB
Re: ATF fluid life sitting in cold garage [Re: rooflessVW] #5260256 11/06/19 08:55 PM
GumbyJarvis Offline
Originally Posted by rooflessVW
Well.
This
Shake it up, anything that isn’t fully in suspension will come loose in the bottle and be mixed once your tranny gets hot enough.
2018 Ram 1500 5.7L SLT
Group 7 V2222 - Mobil 1 Truck & SUV 5w30
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260259 11/06/19 08:58 PM
Well it's unanimous. That'll save me about a hundred bucks. Thanks guys!
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260283 11/06/19 09:42 PM
Chris142 Offline
My dad's 68 valiant he bought new went to it's new owner in 2015 or so with its original atf in it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260305 11/06/19 10:15 PM
MolaKule Offline
Global Moderator
Global Moderator
If the seals on the caps have not been broken or bottles opened you're good to go.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260413 11/07/19 04:51 AM
L
Lubener Offline
L
It would last decades in your garage.
The "thinking" man's friend.
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260455 11/07/19 07:12 AM
G
Gebo Offline
G
Is it a 6 pack or a 12 pack case? All the "newer" cases are 6 packs with little punch out finger holes to help carry. Very nice, indeed.
Ain't it great when something like this happens? Like finding money in your underwear drawer
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: ATF fluid life sitting in cold garage [Re: Gebo] #5260486 11/07/19 08:06 AM
L
LotI Offline
L
Even better is finding cash in some of your ex’s stuff that was left behind. smile2
OP, use it. I’m using locktite from my first job in the late 80’s and it still works fine!
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
19 Buick Regal TourX
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260501 11/07/19 08:31 AM
toneydoc Offline
Use it
1994 Jeep 168k NextGen 10w30
2014 Camry 44k Castrol Magnatec 0w20
2018 Jeep Cherokee 8k Pennzoil Platinum 5w30
2014 HD Ultra 51k Mobil1 15w50
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260506 11/07/19 08:39 AM
W
WyrTwister Offline
W
I know pretty much nothings about Toyotas , but I would use it . Not like it was milk , left sitting in your garage for that long ( not refrigerated ) .
s
Wyr
God bless
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260560 11/07/19 09:25 AM
code5coupe Offline
Those "severe" temp extremes are nothing compared to the temp extremes ATF experiences in a transmission. Think about it.
Consider that fluid to just be in hibernation until someone puts it in their car.
1996 Corvette LT4
2012 Grand Cherokee SRT
1987 VW Scirocco 16V
Misc others , including four 4-wheel drives
Re: ATF fluid life sitting in cold garage [Re: SouthDakotaDad] #5260720 11/07/19 12:29 PM
N
nthach Offline
N
As long as the bottles are sealed from the factory, you're good to go.
WS is hygroscopic, the original formulation from Idemitsu or XOM Japan turned purple upon exposure to air. The current blend from XOM doesn't.
