what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
81 registered members (Aero540T, bbhero, carviewsonic, blufeb95, aquariuscsm, 01VFR, 11 invisible), 1,941 guests, and 17 spiders.
Topics301,893
Posts5,204,799
Members70,798
Page 1 of 6 1 2 6
Anyone still using 20w50? #5260165 11/06/19 06:14 PM
M
mpack88 Offline OP
M
Is there anyone that still fans of 20w50 or is that weight obsolete now. I'm curious of using in my 88 Ford f150 302 in the summer.
Re: Anyone still using 20w50? [Re: mpack88] #5260170 11/06/19 06:16 PM
J
Jimmy_Russells Offline
J
No point really unless it's an oil burner. I have literally had that same engine making over 650 hp and used 10w30.
Re: Anyone still using 20w50? [Re: mpack88] #5260182 11/06/19 06:26 PM
T
Tahoe4Life Offline
T
I put 20w50 in a 88 Town Car with the 302. I thought it would blow up when I started it when the engine was cold as it made so much noise. Took it out a few days later and went back to 5w30 and 10w30. All was nice and quiet again.
2016 Chevrolet Tahoe LT
Mobil 1 0w20 AFE or EP
AC Delco Filters
Re: Anyone still using 20w50? [Re: mpack88] #5260198 11/06/19 06:49 PM
Bud Offline
Still use it in my 71 MGB
2016 Honda Pilot EX-L with NAVI.....Mobil 1 0w20 AFE and Honda OEM Filter
Re: Anyone still using 20w50? [Re: mpack88] #5260204 11/06/19 06:57 PM
M
mpack88 Offline OP
M
Well I don't see smoke, but it does use 1qrt every 1k.
Re: Anyone still using 20w50? [Re: mpack88] #5260207 11/06/19 07:02 PM
skyactiv Offline
Why not just be old school and use a 30W?
[Linked Image]
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Anyone still using 20w50? [Re: Bud] #5260208 11/06/19 07:02 PM
Malo83 Offline
Use it in my tired 305 during the summer triple digit summers.
Re: Anyone still using 20w50? [Re: mpack88] #5260211 11/06/19 07:05 PM
skyactiv Offline
Re: Anyone still using 20w50? [Re: mpack88] #5260212 11/06/19 07:05 PM
R
Red91 Offline
R
Nothing wrong with it in the right application. It has never had many fans on this forum, but I've used it on and off over the years in Chevy small blocks
I like skyactivs suggestion of a straight 30 for your 302 as well. I think you'll actually find more people here favor 30 than 20/50.
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Anyone still using 20w50? [Re: mpack88] #5260219 11/06/19 07:15 PM
R
Randy_R Offline
R
My brother-in-law used in an MG Midget recommended for engine and trans I think a lotta Brits in that era used the same
2018 Mazda CX-5 6600 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 65,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 K&N
Re: Anyone still using 20w50? [Re: Red91] #5260222 11/06/19 07:23 PM
M
mpack88 Offline OP
M
How cold or hot can straight 30 be used?
Re: Anyone still using 20w50? [Re: mpack88] #5260225 11/06/19 07:26 PM
U
userfriendly Offline
U
I have 12 quarts of 20w50 Castrol motorcycle to try in my Duramax LML next spring.
You can make your own 20W50 by adding SAE 50 to 15W40.
Re: Anyone still using 20w50? [Re: mpack88] #5260231 11/06/19 07:30 PM
B
bunnspecial Offline
B
I use more 20W-50 than any other weight.
Having two old British Leyland vehicles around that spec it, plus badly worn rings on the one that gets driven the most by far means that I can easily chew through a lot of the stuff.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
1974 Austin Marina GT VR-1 20W-50
Re: Anyone still using 20w50? [Re: mpack88] #5260232 11/06/19 07:32 PM
O
OVERKILL Offline
O
Can't remember if that one had the intake with the PCV in a grommet on the back of it like the car engines, but if it does, there's a screen underneath it that gets plugged up and causes oil consumption. The 302 definitely does NOT need 20w-50, I'd run a cheap 15w-40 in it given your location and the fact it is consuming.
Re: 20w50 [Re: mpack88] #5260234 11/06/19 07:34 PM
B
bullwinkle Offline
B
It's been stated, both here & in my GM diesel owner's manuals (6.2 ones) that 32F/0C is pretty much the minimum recommended temp for SAE 30 dino, although if a little warm up is allowed & it'll crank fast enough to start, I would go as low as zero to +5F. I've started (worn-out) engines with 20W50 below 0F before with no issues.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Page 1 of 6 1 2 6
