Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Snow Shovel Recommendations ?
by Dwight_Frye - 11/21/19 01:29 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
89 registered members (69GTX, Aero540T, 2015_PSD, 4WD, agpatel, 6 invisible), 1,643 guests, and 23 spiders.
Topics297,752
Posts5,121,884
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Head Gasket Leaking In Cylinder and Causing Misfire #5260144 11/06/19 05:59 PM
RDY4WAR Offline OP
2006 Nissan Altima
2.5L 4 cylinder
233k miles
The radiator cracked on this car earlier this year and the wife didn't notice anything was wrong until it bucked hard trying to accelerate from a light and looked down to see the temp gauge on the H. I replaced the radiator, but ever since it's been going through about a quart of coolant every 200-250 miles. Some stop leak did absolutely nothing. I've accepted I need to replace the head gasket, but we both agree that it's time for a new(er) car anyway. We're just trying to limp this thing along until after the New Year.
Back story out of the way... the coolant leak is occurring in the #2 cylinder and causing a misfire that only occurs after coasting in gear for a while such as on an exit ramp coming off the highway. I'm assuming this is because the CPU is shutting off the fuel (and therefore combustion) to the cylinders when coasting in gear, allowing the cylinder to fill with a little bit of coolant, and when you get back on the gas, the cylinder isn't firing. When this occurs, I usually just bump it into neutral and peg it off the rev limiter for a second to clear it out, and all is well... much to my wife's dismay. At least my daughter finds it funny.
My solution to the issue is anytime I'm coasting/braking, I just bump it to neutral so the fuel doesn't shut off and the cylinders keep firing, not allowing that cylinder to get wet down with coolant. My wife, however, finds this to be an impossible task and almost every time she drives it, I get a call from her sitting still at a green light complaining about the car doing that "thing" again and she doesn't know what to do. So, I'm looking for a better solution.
It's worse when the plug is caked up with deposits from burning coolant. I take it out and clean it every month or so, and it doesn't seem to do it for a little while until it gets cruded up again. I thought about going to a hotter spark plug (from NGK LFR5A to LFR4A) in hopes that it could keep the tip cleaner, along with a wider gap for a larger flame kernel that might could pierce through the moisture in the cylinder. Then hope the added resistance doesn't kill the coil before we sent it to its grave. Does anyone have any thoughts on this? Is that a viable solution?
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260152 11/06/19 06:06 PM
A
atikovi Offline
A
Stopleak is for a radiator leak. You need a head gasket sealer for your problem.
[Linked Image from images-na.ssl-images-amazon.com]
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: atikovi] #5260169 11/06/19 06:16 PM
rooflessVW Offline
He needs a head gasket for his problem.
I don't see the point in trying to limp a car along that could fail spectacularly at any moment.
Repair or trade the poor thing in.
"Zed's dead baby, Zed's dead."
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: rooflessVW] #5260172 11/06/19 06:18 PM
G
GZRider Offline
G
+1
Ditch the car, ditch it now while it runs.
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260178 11/06/19 06:20 PM
domer10 Offline
Would the coolant not be making its way into the oil as well? I do not see that car making it much longer without some sort of permanent failure.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260187 11/06/19 06:33 PM
X
xxch4osxx Offline
X
Wait till it leaks coolant into the cylinder after it is shut off for a while, enough to hydrolock it when you go to start it. Seen it happen with a big truck engine that had cavitation issues with the liners.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: rooflessVW] #5260190 11/06/19 06:39 PM
A
atikovi Offline
A
Not worth the cost on a 13 year old Altima with 200K+ miles to replace the headgasket, unless you DIY, but even then... Sealer could get you a few more years for just $50.
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260203 11/06/19 06:54 PM
super20dan Offline
blue devil works 50$ well spent
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260209 11/06/19 07:04 PM
CARJ Offline
It's certainly worth trying the HG stop leak, especially if you agree that you would replace the car in January. Long term, that stuff can clog up the heater core which really leads to expensive repairs. A running car will always sell for more than one that isn't.
2004 Toyota 4Runner | 193k | Havoline Pro DS 5w-30, YZZD3
2012 VW Passat | 96k | M1 0w-40, XG9911
1997 Honda Civic HX | 222k | M1 0w-30, PH3593a
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260227 11/06/19 07:28 PM
B
bullwinkle Offline
B
Waiting for "screwing the next owner" comments in 3...2...1... LOL I agree with trying the HG repair stuff, you'll pull the head & likely discover it needs resurfaced, maybe valves, a valve job, maybe even rings. In a disposable Altima!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260239 11/06/19 07:39 PM
W
Warstud Offline
W
I put K&W Fiberlock in my vehicle back in March and it's been fine ever since.
https://www.ruralking.com/kw-fiberl...bkfvW5QIVDvbjBx2aNgWjEAQYAyABEgKvWvD_BwE
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: domer10] #5260244 11/06/19 07:46 PM
Chris142 Offline
that's kind of a wives tail.
. It burns off before it gets into the oil unless it's absolutely dumping coolant into the cyls.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: bullwinkle] #5260271 11/06/19 08:22 PM
RDY4WAR Offline OP
That wouldn't be much of an issue as I have the equipment to mill the heads and cut the valve seats. It's just not worth the effort to me. I'll probably do it anyway so I can sell it for a better price. It's just that doing that takes time away from other projects.
I'll try the fix in a bottle and see if it helps. If it doesn't, oh well.
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: RDY4WAR] #5260272 11/06/19 08:23 PM
Z
zzyzzx Offline
Z
Use a head gasket sealer.
I would have used it on my car, but I pulled the valve cover and found loose and broken head bolts, so I replaced the head gasket. Probably spent less than $100 and replaced a bunch of other stuff at the same time. Now I have a car with 2 less oil leaks, and no coolant leaks (for the first time in more than 10 years). Really wasn't that hard, just tedious.
Re: Head Gasket Leaking In Cylinder and Causing Misfire [Re: Chris142] #5260314 11/06/19 09:22 PM
domer10 Offline
Just figured since it’s misfiring, there is no combustion taking place...but I guess still be hot enough to burn off.
2001 Toyota 4Runner
