Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Need earbud recommendations!
by cwilliamsws6 - 11/21/19 01:50 PM
Snow Shovel Recommendations ?
by Dwight_Frye - 11/21/19 01:29 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
89 registered members (69GTX, Aero540T, 2015_PSD, 4WD, agpatel, 6 invisible), 1,643 guests, and 23 spiders.
Topics297,752
Posts5,121,884
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Page 1 of 5 1 2 5
How can both of these oils be excellent options? #5260023 11/06/19 03:21 PM
A
ad244 Offline OP
A
Hey Guys,
I just have a quick question which stems from alot of the advice and discussions which I am commonly reading through. Specifically a "Cheaper" oil and a "Top Tier" oil both being excellent choices for ordinary passenger vehicles (...?)
Im just going to use for Example, Chevron Supreme Motor oil (commonly in the $12-$14 for 5 quarts) and Mobil 1 (commonly in the $22 - $30 for 5 quarts). My question is: How can both of these oils be recommended and praised as excellent oils when one is conventional, not specifically formulated for extreme or extended use. Is it because the users are typically not trying to over use the oil with an extended OCI or are we strictly looking at TBN to weigh the "Quality" of the oil?
Re: How can both of these oils be excellent options? [Re: ad244] #5260034 11/06/19 03:34 PM
Direct_Rejection Online Content
Online Content
Originally Posted by ad244
Hey Guys,
Chevron Supreme is Group III, hydrocracked, plus Chevron has their own add pack.
Also this oil is turbo rated.
Mobil 1 EP is also an exceptional value, and is stellar, stellar stuff.
Your vehicle, the spec'd oil, and your driving conditions should sway your decision on which oil to use.
2019 Lexus UX 250h F-Sport
13,918 miles
Pennzoil Platinum 0W16
ILSAC GF-6B
"GTL all day."
Re: How can both of these oils be excellent options? [Re: ad244] #5260038 11/06/19 03:36 PM
d00df00d Offline
Two reasons:
1. Either one would meet or exceed the requirements of the application, and
2. People are talking WAY beyond what they can possibly know.
2008 BMW M3 Sedan 6MT
Re: How can both of these oils be excellent options? [Re: ad244] #5260040 11/06/19 03:37 PM
K
KGMtech Offline
K
The new conventional oils are, with some exceptions from what I hear, very close to the performance of full synthetics. The differences are very small, but there are differences to justify one over the other.
If your car has a turbo, if you drive in an area of extreme temperatures, if you want to keep your car 10+ years, if you have the standard BITOG oil anxiety syndrome, a full synthetic is a better choice.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: How can both of these oils be excellent options? [Re: ad244] #5260043 11/06/19 03:41 PM
GumbyJarvis Offline
Both are good oils when used in their proper applications.
Both oils contain mfgr specs and API certification.
Quote
Mobil 1 5W-30 synthetic motor oil meets or exceeds the requirements of:
ACEA A1/B1, A5/B5
API SN, SM, SL, SJ, SN PLUS, SN PLUS RESOURCE CONSERVING
ILSAC GF-5
Ford WSS-M2C946-A
Ford WSS-M2C946-B1
Mobil 1 5W-30 has the following builder approvals:
General Motors Service Fill dexos1™ Gen 2 (license number D10104GH015)
Honda/Acura HTO-06
Mobil 1 5W-30 is recommended by ExxonMobil for use in applications requiring:
General Motors 4718M
General Motors 6094M
Ford WSS-M2C929-A
Quote
Chevron Supreme Motor Oils meet:
• API Service Categories
— SN PLUS
— SM, SL, SJ and all previous API “S” categories
— Resource Conserving for API SN PLUS
(SAE 5W-20, 5W-30, 10W-30)
— ILSAC GF-5 (SAE 5W-20, 5W-30, 10W-30)
• manufacturers’ performance requirements
— FCA US LLC (formerly known as Chrysler Group
LLC)
MS-6395 (SAE 5W-20, 5W-30, 10W-30)
— FIAT
9.55535-CR-1 (SAE 5W-30)
— Ford
WSS-M2C945-A (SAE 5W-20)
WSS-M2C946-A (SAE 5W-30)
— General Motors
GM 6094M (SAE 5W-20, 5W-30, 10W-30)
Look at your OM, if the oil meets the specs (Dexos, Ford, MS6395, ACEA, etc) that oil is adequate for the recommended oil change of that vehicle.
For example, a Hyundai 1.6T says use ACEA A1/A5 for 5k ocis. Looking at the spec sheets, Mobil is the better oil for this application as it meets OEM requirements, and should be fine for the rec 5k oci.
At the same time, both oils contain the Ford spec. So, if your Ford says use the WSS spec, both oils will be fine for the OEM oci recommendation.
People on here fail to realize this sometimes. If your Ford or Nissan or whatever reccomends a 5k oci, both will be fine for that as they both meet spec. The engine isnt going to get hurt. The only thing getting hurt is your pocketbook.
I have a hunch theres plenty of people out there running 25-40$ jugs of oil and an expensive 8-15$ oil filter for 5K (average OCI for most) when they would be fine with a 12$ jug and a 3$ filter. shrug
2018 RAM 1500 SLT 5.7L
Formula Shell Conventional 5w20 - Fram Tough Guard
Disabled US Army Vet
OEF 2013-2014
Re: How can both of these oils be excellent options? [Re: ad244] #5260046 11/06/19 03:44 PM
SirTanon Offline
Both are quality brand-name oil that carry API and other industry approvals and ratings. Both Chevron Supreme and Mobil 1 carry API SN (or better) approval, Dexos approval, etc.. Just because one is conventional and one is synthetic does not mean that both can't be used with confidence and excellent results in a given car's engine.
My 2013 Altima, for example. Either of these oils would perform exceptionally well in my Altima's 2.5 engine over the course of a 7,500 mile OCI, even though I drive the car year round in Phoenix. Both will provide top-notch lubrication, wear protection, etc.. over the course of the OCI. Of course, a 7,500 mile OCI for me, in this car, is about 3 - 3.5 months. It does not matter that one is conventional and one is synthetic in my case because it almost never drops below freezing here, and hot weather does not increase wear or oxidation inside the engine (which operates at or over 200F almost all the time).
Now, if I lived in northern Minnesota or Alaska, and/or if my trips were all very short and my OCI was over a year, then I'd probably want the synthetic to allow for better cold temp flow, etc..
Also, keep in mind that the base stock, while important, is only ONE factor in how well the oil will perform. The additive pack is also VERY important, and I can guarantee that Chevron Supreme conventional has a very good add pack.
2013 Nissan Altima SV - 2.5 liter/CVT - 124,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: How can both of these oils be excellent options? [Re: ad244] #5260064 11/06/19 04:19 PM
I
Imp4 Offline
I
Hey Guys...
Another way to phrase this question is to ask how a 12-foot ladder and a 15-foot ladder are both adequate for getting out of a 10-foot hole.
The answer is they both exceed the requirements for success. cheers
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: How can both of these oils be excellent options? [Re: Imp4] #5260066 11/06/19 04:23 PM
O
OilReport99 Offline
O
Hey Guys...
You beat me to it. I suspect the OP’s question has more to do with economics that oil performance - he’s questioning the difference in dough, not in stuff in the oil - all other things being equal, the 15’ ladder will be more expensive.
Re: How can both of these oils be excellent options? [Re: d00df00d] #5260081 11/06/19 04:46 PM
N
nascarnation Offline
N
Without this...would BITOG even exist....
grin2
Re: How can both of these oils be excellent options? [Re: ad244] #5260099 11/06/19 05:11 PM
B
billt460 Offline
B
Just use the weight and spec type the manufacturer recommends. For many vehicles manufactured today that doesn't offer a very large window of choice. Years back that wasn't the case. You could pretty much run anything and it wouldn't matter.
But now as engines get more complicated with computer codes, variable valve timing, along with cylinder deactivation systems, turbochargers, and all the rest, they require a limited range of oils to choose from. Everyone who cares about their cars wants to use a good grade of oil. That said everything has it's limits. Most won't pay $90+ for 5 quarts of "boutique oil". Simply because they are not convinced it's twice as good as brand name $35 oil.
Re: How can both of these oils be excellent options? [Re: Imp4] #5260107 11/06/19 05:21 PM
M
Mad_Hatter Offline
M
Hey Guys...
Good analogy.👍
Very true.. it's not like Chevron has its own additives R&D Div. coughs *Oronite* coughs, or anything.😉
Re: How can both of these oils be excellent options? [Re: ad244] #5260112 11/06/19 05:28 PM
B
bullwinkle Offline
B
Hey Guys,
The M1 is generally good for at least 10K miles, but the Chevron Supreme (which is actually a synthetic BLEND in 5W20 & 5W30) is one of the better so-called lower priced oils, and could be used for full OLM life-which in my Transit 250's case, is almost 10K miles (usually 9200-9500). If you're not driving in uber-cold arctic conditions, and don't believe in pushing oil changes too far, Chevron Supreme would be a great choice. Of course, Mobil 1 has much better marketing... crazy
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: How can both of these oils be excellent options? [Re: ad244] #5260123 11/06/19 05:40 PM
J
JLTD Offline
J
Hey Guys,
The different interval you use each of the oils.
I use the overseas manual to choose my viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: How can both of these oils be excellent options? [Re: d00df00d] #5260127 11/06/19 05:45 PM
M
Mad_Hatter Offline
M
Can you provide an example of what you mean..as it relates to the OP's question???
Re: How can both of these oils be excellent options? [Re: JLTD] #5260132 11/06/19 05:48 PM
GumbyJarvis Offline
Hey Guys,
Uhh,
They both meet Ford spec, so
If a N/A Fiesta or Focus recommends 10k ocis, theyll ideally both go 10k mi, because ford has approved it.
I'm sure mobil 1 could probably further, but a car under warranty, extended oil changes can be considered "neglectful maintenance" in the eyes of the OEM who says 10k and no more.
Under warranty, any oil that meets the OEM spec and is API certified should be able to cover the recommended oci. After the warranty is up, extend all you want, but for warranty purposes on a vehicle such as a Ford, where both oils meet spec, Mobil 1 is equal to Supreme and any other Ford specced oil
OEF 2013-2014
Page 1 of 5 1 2 5
