BMW Diesels
by Trix - 06/04/20 12:21 PM
Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
93 registered members (4WD, Anduril, 14Accent, 77GrandPrix, ABN_CBT_ENGR, amblerman, 8 invisible), 2,092 guests, and 74 spiders.
Topics306,135
Posts5,288,105
Members71,604
Fram extra guard or Orielly's Microgard #5259847 11/06/19 11:42 AM
Corollaman Offline OP
The Fram extra guard has silicone ADBV, higher efficiency. The microgard seems to be built better with a stronger shell, at least to me. Both about $4.
Third option Fram Ultra for two oil changes for me would be 8,000 to 9,000 miles total.
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5259848 11/06/19 11:47 AM
czbrian Offline
Fram Ultra for two intervals. I wouldn't be afraid to do 3 intervals if you are only talking 15K miles.
2019 Honda Pilot
1998 Chevrolet C1500
1995 Chevrolet C1500
2018 Mitsubishi Outlander PHEV
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5259852 11/06/19 11:50 AM
JohnnyJohnson Offline
I can generally get a Fram anyplace the Microgard basically at O'Really's. O'Really's stock is over $400 a share for a reason. Did the light turn on?
2004 Corolla 140120
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5259857 11/06/19 11:59 AM
GumbyJarvis Offline
Is it for a Corolla?
Because if it is, the filter isnt going to matter much, that car could go 200-300k easily on the cheapest filter and in spec oil avaliable
2018 Ram 1500 5.7L SLT
Group 7 V2222 - Mobil 1 Truck & SUV 5w30
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5259868 11/06/19 12:27 PM
2011 4.3 silverado. Olm goes off at about 4,000 miles.
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5259878 11/06/19 12:42 PM
GumbyJarvis Offline
Why not run an Acdelco?
Re: Fram extra guard or Orielly's Microgard [Re: czbrian] #5259888 11/06/19 01:02 PM
J
JeffKeryk Offline
J
Yup. What he said. Easy peasey.
To answer your question, flip a coin. Both are fine.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Fram extra guard or Orielly's Microgard [Re: GumbyJarvis] #5259922 11/06/19 02:10 PM
I was actually running the Supertech 3387a which is a clone of the AC pf47E. The filter location is easy but makes a mess, that's why running a Ultra for two oil changes sounds appealing.
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5260009 11/06/19 04:00 PM
GumbyJarvis Offline
The Supertech is rated to 10K miles though, why not just run one for two 5k ocis?
I understand filters being in horrible areas, my Ram is the same way, i have to finagle my arm in unnatural positions and when it does come loose, everything under it's now rust coated with used oil. But, I'm not one to run a filter twice, since I'm crawling under anyway, but if its rated that long, why not? Then cut the filter open for all of us to gush over.
Re: Fram extra guard or Orielly's Microgard [Re: GumbyJarvis] #5260012 11/06/19 04:03 PM
That is true but I'm not that convinced yet about running an ecore for 9,000 miles, I'd like to know if anyone here has run one that long.
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5260016 11/06/19 04:07 PM
GumbyJarvis Offline
Stude cut open a Champ ran for 2x 5k ocis.
It was fine.
https://www.bobistheoilguy.com/foru...67037/champ-ph-500-10-000-miles-cut-open
If you're still hesitant, I think AcDelco UltraGuards are around, and are steel centertubes.
Re: Fram extra guard or Orielly's Microgard [Re: GumbyJarvis] #5260042 11/06/19 04:41 PM
53' Stude Offline
It was fine.
Yeah, I would run a Champ Labs to 10k without issue. Hard to go wrong with AC DELCO
2009 Toyota Camry LE
Re: Fram extra guard or Orielly's Microgard [Re: 53' Stude] #5260059 11/06/19 05:05 PM
GumbyJarvis Offline
It was fine.
I mean. They do make SuperTech filters that are rated to 10k, I highly, HIGHLY doubt walmart is gonna pay Champ for a better filter than the regular old white can.
OP I was in the same boat once as you, hesitant to use Ecores, when they first came out we saw media blowouts almost daily, those days are gone, the cages have tighter clearances and are fine. I've ran LuberFiners for 8-10k miles, no issue. The best thing is you can literally see if theres media tears usually. Plenty of semi trucks run Luberfiner ecores as well, for 20k+ miles.
Re: Fram extra guard or Orielly's Microgard [Re: Corollaman] #5260174 11/06/19 07:19 PM
I've got two Supertech ecore filters the ST3387a and the longer version ST3890, I was thinking of trying to use the larger capacity filter for the year interval. I know many people use the longer ac pf52 in place of ac pf47.
Re: Fram extra guard or Orielly's Microgard [Re: GumbyJarvis] #5260724 11/07/19 12:34 PM
B
Bettez88 Offline
B
Ditto
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
