Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
104+ Fuel Injector Pro ?
by ChrisD46 - 11/12/19 04:55 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
96 registered members (92saturnsl2, 53' Stude, 1foxracing, 2010Civic, 1978elcamino, aircooled, 4 invisible), 2,075 guests, and 27 spiders.
Topics297,341
Posts5,113,567
Members69,842
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Brake Pad Comparison #5259828 11/06/19 09:57 AM
J
JeffKeryk Offline OP
J
I generally hate cheap tools and especially replacement parts.
Of course brakes are really important.
I don't think I have ever bought cheapo brake parts.
I found this comparison very interesting:
Brake pad comparison of 5 different pads.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Brake Pad Comparison [Re: JeffKeryk] #5259855 11/06/19 10:57 AM
doitmyself Offline
It is very interesting. About the only conclusion you can take away is that the test sponser (NRS) makes a very good brake pad. We know nothing about the other pads and we can not assume from the test that all budget pads are bad nor that all aftermarket mid and top tier pads are better or worse than NRS and/or OEM.
The test fails to prove that you get what you pay for regarding all brake pad brands.
Re: Brake Pad Comparison [Re: JeffKeryk] #5259856 11/06/19 10:58 AM
SirTanon Offline
Ah, cool. I like Engineering Explained's videos. IMHO, he does a great job of testing and explaining results. I've watched a ton of his videos and he always does a good job of keeping things interesting, but at the same time being informative and clear.
In this case, most of his testing results seemed to be pretty much what I expected, with a few surprises. I honestly did not expect to see the 'mid tier' pads do as well as they did overall, compared to the rest.
On a side note - I found the NRS Brakes testing facility and methods quite interesting. It appears to really put the pads through the gauntlet.
I do have to wonder how applicable many of the tests are to real-world use. I mean, sure, there ARE places in the USA where corrosion is a serious concern, and I'm sure there are vehicles who see similar brake wear and abuse.. but how many? Yes, these tests are meant to represent the absolute worst-case scenario, and it's good to know how that could impact my ability to stop in a bad situation, but what's the over/under of that situation happening with the average commuter?
Having said, this, I do appreciate what it does represent. When your whole family is in the car with you, it makes a difference.
2013 Nissan Altima SV - 2.5 liter/CVT - 123,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 69,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: Brake Pad Comparison [Re: JeffKeryk] #5259887 11/06/19 11:59 AM
N
nthach Offline
N
NRS/Nucap is one of the major suppliers of backing plates/hardware/shims to the aftermarket and their new pads are supposedly made in Canada when going to Asia is now common with all but a few suppliers. Most parts store pads are from China or India and MAT Holdings has scored big contracts from the chains. They also bought the rights to the Bendix name from Honeywell/Garrett but those are too made in China or India. Even Raybestos is now made in China - used to be US or Canada.
OEs can get specific with each vehicle, while aftermarket pads stick to AMECA/FMSI specs. As long as you don't install a budget pad, you can get decent to good braking with aftermarket pads but don't expect performance as intended when the car is new.
With that said, I've had luck with Wagner pads on a friend's truck but not with my own car. I've installed Worldpac's WBR pads on for a friend's car and despite being Chinese made, they worked OK. I had to pull a set of Toyota's "value line" pads off my parent's van due to noise. In went a set of the "warranty" spec pads from Japan. No complaints since.
Re: Brake Pad Comparison [Re: JeffKeryk] #5260029 11/06/19 03:29 PM
Davejam Offline
This was interesting to see how brakes can be tested. But not knowing what the brands are is frustrating.
At least it seemed fair in the fact that the mid quality tested reasonably well.
Why would they even manufacture low quality brakes. Why would anyone cheap out on brakes.
Re: Brake Pad Comparison [Re: SirTanon] #5260047 11/06/19 03:44 PM
G
geeman789 Offline
G
Originally Posted by SirTanon
I do have to wonder how applicable many of the tests are to real-world use. I mean, sure, there ARE places in the USA where corrosion is a serious concern, and I'm sure there are vehicles who see similar brake wear and abuse.. but how many? Yes, these tests are meant to represent the absolute worst-case scenario ...
I just replaced front brakes on our Mazda 2 primarily because of severely rusted rotors and pads, which were binding in the caliper. My Subaru has a rear brake noise which upon teardown is the result of severely rusted brake pads, with one actually coming apart.
So, yes, corrosion resistance is important for many owners ... rust sucks.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Brake Pad Comparison [Re: JeffKeryk] #5260053 11/06/19 03:53 PM
P
pitzel Offline
P
The video didn't exactly contain much, if any actionable information (other than, perhaps, don't buy the $10 pad sets). Not even mention of whether the ceramic composites have better performance than the older-style semi-metallic, etc.
I would've liked to have seen the relationship between pad material, pad wear, and brake rotor wear explored.
For example, there are some pads which allegedly wear the pad quickly, but do not pose much wear on the rotor. Or vice versa. Is an optimal brake pad one that provides for a relative balance of wear on the components? Or are there pad materials (and/or construction techniques) that legitimately provide a superior combination of lower rotor wear and lower pad wear, while not compromising on performance?
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Brake Pad Comparison [Re: JeffKeryk] #5260058 11/06/19 04:01 PM
W
WhizkidTN Offline
W
I've had some poor experience recently with replacing the OEM brakes at 85K original miles on my Optima at Firestone. First went in a set of NAPA Ceramic pads as an "upgrade" which squealed. Then the Wagner ThemoQuiet pads (which was what Firestone normally uses) went in next after two weeks which then also squealed for another two weeks of my testing. Very frustrated at this point, then came the $65 upgrade I was charged to put in Adaptive One (ADO) high end ceramic brake pads which rarely squeal now so I'm mostly happy. These don't seem to "grab" or "bite" quite as good as the Wagner pads did but are more like the OEM pads. All were sourced from NAPA locally by Firestone.
Yes, the rotors were turned. Yes, the brakes were bedded properly. No I don't think the brake hardware kit (or lube) was used on the first set of pads that went in (and they should have been) but did with the third ADO set.
Go figure. About a year prior to this I had them do the brakes on the wife's Rogue using the Wagner ThermoQuiet pads with no issues whatsoever.
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (85K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (94K)
>EDGE 0W-20, Fram XG6607/XG7317
Re: Brake Pad Comparison [Re: Davejam] #5260084 11/06/19 04:48 PM
The Critic Offline
From what I recognize, the OE pads look like front pads for a Honda....most likely an Accord.
Of the aftermarket pads, the mid-tier option looks like a Duralast Gold pad that someone removed the logo from.
This is true. However, the test confirmed what I suspected - OE is generally a very safe choice.
2011 Toyota Prius 1.8L - 199K - Pennzoil Platinum 0W-20
2007 Honda Accord 2.4L - 140K - Valvoline Premium Blue Restore 10W-30
Re: Brake Pad Comparison [Re: WhizkidTN] #5260087 11/06/19 04:50 PM
N
nascarnation Offline
N
I didn't know anybody did that anymore, at least in first world countries.
Re: Brake Pad Comparison [Re: nascarnation] #5260090 11/06/19 04:52 PM
The Critic Offline
Out here, most dealerships (for Asian brands) will resurface the rotors with their brake jobs, usually with an on-car lathe. $350-$425/axle for new OE pads and resurfaced rotors is the market rate in my area.
Re: Brake Pad Comparison [Re: The Critic] #5260098 11/06/19 05:04 PM
cb_13 Offline
I work at a Ford dealership and we will turn the rotors as long as there is enough material to keep them above minimum thickness. We do package pricing on a brake service for passenger cars which is $179.95 per axle for new pads, machining the rotors, lubing caliper slide pins and labor. The motorcraft pads also carry the lifetime replacement warranty so if the customer owns it long enough to wear them out the pads are free at the next service. Not a bad deal for those that are not DIY capable.
Re: Brake Pad Comparison [Re: cb_13] #5260108 11/06/19 05:22 PM
W
WhizkidTN Offline
W
Yup, pretty much what Firestone did and charged me for (also with lifetime replacement warranty on the pads). If not for the squealing pads, I'd been a happy camper.
Re: Brake Pad Comparison [Re: nascarnation] #5260109 11/06/19 05:22 PM
P
pitzel Offline
P
My car's factory service manual says explicitly to not to ever resurface the rotors unless there's an identifiable customer complaint. Not sure where this 'turning' or 'replacing' rotors business as a matter of ordinary routine (rather than to correct an actual problem) came from, other than salesmanship of the car repair industry.
Re: Brake Pad Comparison [Re: nascarnation] #5260116 11/06/19 05:34 PM
SirTanon Offline
All the O'reilly Auto stores near me will turn a rotor for you for $10, as long as there's enough material left on the rotor to keep it within spec. I've used their service a couple times in the past. Combine that with a decent set of pads on discount/sale, and I save tons of money.
Page 1 of 3 1 2 3
