Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
Tesla Truck Reveal
by Aero540T - 11/21/19 10:06 PM
DIY Engine Rebuild Costs
by Spetz - 11/21/19 10:01 PM
Killer rod
by P10crew - 11/21/19 09:51 PM
Do you need to shake clear cans of spray paint?
by atikovi - 11/21/19 09:20 PM
Is this an accurate test on motor oil
by Tboss - 11/21/19 08:57 PM
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi
by SavagePatch - 11/21/19 08:48 PM
Discount tire lift question
by NissanMaxima - 11/21/19 07:32 PM
Mazda CX-30
by buster - 11/21/19 06:39 PM
ATF for a MP3010 Transfer case??
by nitecop - 11/21/19 06:34 PM
Cutting Open Orange Cans
by KevGuy - 11/21/19 06:26 PM
Great Canadian Oil Change - What Oil?
by KevGuy - 11/21/19 06:18 PM
Dexron 6 or Dexron VI ???
by brages - 11/21/19 04:53 PM
PP on great deal for Canadians this week
by Jimmy_Russells - 11/21/19 04:40 PM
Ford Maintenance Schedule
by borgward - 11/21/19 04:22 PM
hotshot fr3 oil additive?
by dogememe - 11/21/19 02:27 PM
Turtle Wax Hybrid Ceramic
by Toros - 11/21/19 02:01 PM
Corslayth, oildud, Kylefl1, JDee71, trgfunds
69936 Registered Users
52 registered members (01rangerxl, CARJ, 4WD, BlakeB, bbhero, 2 invisible), 1,329 guests, and 21 spiders.
Topics297,754
Posts5,121,919
Members69,936
Most Online3,589
Nov 2nd, 2019
Rate Thread
Chain Wheel Hub assemblies.... #5259378 11/05/19 06:58 PM
M
mjk Offline OP
M
Hello,
If for a specific reason a person was limited to ordering a hub assembly for a 01 Tahoe from a chain, which house brand would you choose? Yes, I am aware of RA, etc.... and order from them.
But again for this specific instance, you had to order a house brand ......
I've already read the Oreillys Master Pro line..absolute garbage. Is NAPA's brand any better?
So this doesn't side track, I am aware of Timken, SKF, etc. There is, again, a reason I am soliciting advice on house brands.
Appreciate the input.
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5259398 11/05/19 07:19 PM
L
LotI Offline
L
I would never buy a hub from a “house brand”...much less any part.
Sorry to sidetrack your thread.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX http://www.fuelly.com/car/buick/regal_tourx/2019/loti/943992
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5259442 11/05/19 08:02 PM
N
nthach Offline
N
I think they are all the same between MasterPro, Duralast/Valucraft and ProLine.
I'd get the Duralast one. As much as I have a disdain for AZ, their warranty seems to be the only good thing about them.
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5259488 11/05/19 09:02 PM
Chris142 Offline
According to the guys at AutoZone the duralast ones are made by timkin. They told me that they stopped carrying timkin only to rebox timkin as duralast.
I can't confirm that though. I think the biggest problem with the house brand ones is the grease they use. I have seen guys carefully pry the seals off and add a quality grease.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5259623 11/06/19 03:16 AM
G
GMBoy Online Content
Online Content
G
They are all coming off the same Chinese assembly line and thrown in different boxes. But to answer the original question, if I HAD to buy a chain store hub bearing it would be the autozone one. I get reward points and have a good relationship at the local AZ so I know warranty will be honored hassle free. I used a few AZ white boxes due to customer needing the vehicle asap. I once used an Orielly and it failed exactly 1 year later.
Side note - for a low priced wheel hub, the WJB line available on RockAuto has proven to me to be a darn good bearing for the money. I have been using them the past 2 years when customer wanted a budget repair. I actually have one on my 08 CTS and 2 years so far so good and half the price of the Timken and same warranty. I actually use MOOG over Timken now for customers who will pay for a top line part because they have a 3 yr warranty where Timken is now only 1 year. I don't trust Timken like I used to.
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5259755 11/06/19 08:19 AM
J
john_pifer Online Content
Online Content
J
I just posted a thread about this a couple weeks ago about my Tacoma. I went with Dorman from AZ. Probably not the highest quality, but on a 223,000 mile Tacoma, I didn’t want to spend at least $300/ea for front wheel hub bearing assemblies.
I believe the Dorman has a 1-year warranty. We’ll see how they do. They were <$300 for both.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 222K
18 Civic HB 1.5T 6MT (Fiance's) - Castrol Edge 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Chain Wheel Hub assemblies.... [Re: GMBoy] #5259805 11/06/19 09:22 AM
M
mjk Offline OP
M
I know Moog essentially split into 2 tiers - are the Moog hubs that you are using the Problem Solver line ?
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5260368 11/06/19 11:04 PM
G
Online Content
G
I am not sure, I don't think so. Here is the last one I used from rockauto:
https://www.rockauto.com/en/moreinfo.php?pk=2480228&cc=1441080&jsn=2135
Re: Chain Wheel Hub assemblies.... [Re: GMBoy] #5260725 11/07/19 11:34 AM
N
nthach Offline
N
Side note - for a low priced wheel hub, the WJB line available on RockAuto has proven to me to be a darn good bearing for the money.I don't trust Timken like I used to.
I was about to say WJB or some other Chinese firm is supplying the box store's white box hubs.
Timken used to be a solid pick for bearings but I had a bad apple recently. That bad one was a reboxed Koyo for a Toyota. I've installed a axle set of Timken tapered roller bearings on a friend's Explorer recently and those felt and looked like quality pieces. They were made in France and the US.
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5261186 11/07/19 08:29 PM
M
mjk Offline OP
M
I am in the same boat; replaced w/ Timken 60k ago. Guessing it is going. Having my mechanic look at it in a few weeks.
As for why I am asking about chain parts..... well, trust me, it isn't my call. My mechanic has started to really change his mind on us bringing in our own parts (after 15 years of being fine with it)....
Why you say ? Well, let's just say his newest 'significant other', who is a piece of work, is running the books and calling the shots. And, like a typical woman, she has her favorites. I am not one of them, for unknown reasons. Bills are always paid, I show up on time, I keep my appointments. I guess just another reason I am glad I never married.
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5261234 11/07/19 09:25 PM
G
Online Content
G
She probably doesn't like that they loose money when a customer brings a part in. They mark up parts too as a profit.
Re: Chain Wheel Hub assemblies.... [Re: GMBoy] #5261294 11/07/19 11:26 PM
J
JunkdrawerDog Offline
J
This^^^ My dad used to have this all the time. "Can I bring my own parts?", "Can I disassemble it myself and just have you do the difficult part?", "Can you show me how to do it myself?", "Can I borrow your tools, maybe a little shop space?" Of course his answer was always the same, "NO!"
Re: Chain Wheel Hub assemblies.... [Re: mjk] #5262204 11/08/19 10:32 PM
M
mjk Offline OP
M
I understand the 2 posts above. Understand though, there was a trade off. He just marked up his labor, when bringing in parts to cover the loss.
I'd rather put a quality part in once, with increased labor cost, than doing the job multiple times.
