Will a CV half shaft make noise in 2WD on a 4WD?
by dlundblad - 11/13/19 09:41 AM
Are the new CR-V's really that terrible?
by cwilliamsws6 - 11/13/19 09:34 AM
Proper oil to use in vintage motorcycles
by Crampfan - 11/13/19 09:30 AM
Do You Fly the BITOG Flag?
by ARCOgraphite - 11/13/19 08:42 AM
Boat question, but not lubrication related
by OVERKILL - 11/13/19 07:42 AM
Gifted a 2007 Impala
by 14Accent - 11/12/19 11:02 PM
Premium vs. Budget Snow tires
by edyvw - 11/12/19 10:11 PM
Range Rover 5.0 oil & BG MOA?
by xmreeves - 11/12/19 09:34 PM
Stalling and difficult restart problem
by RDMgr - 11/12/19 09:26 PM
Shying Away From Havoline 5w30
by Mr_Luke - 11/12/19 08:00 PM
New Way To Wash A Car
by buster - 11/12/19 07:52 PM
Sealed vs open bearings. What's better?
by motor_oil_madman - 11/12/19 07:51 PM
Wix WL10290XP CUT OPEN GM 22psi
by LotI - 11/12/19 07:04 PM
Do high beams make you angry?
by 1978elcamino - 11/12/19 06:46 PM
VALVOLINE V0-148 CUT OPEN
by 53' Stude - 11/12/19 06:38 PM
VW Jetta oil filter CUT OPEN
by 53' Stude - 11/12/19 06:31 PM
Turtle Wax Seal & Shine On Top of Ice or Vice-Versa ?
by Dwight_Frye - 11/12/19 06:10 PM
Timing Cover Leak in Toyota/Lexus
by Gebo - 11/12/19 05:10 PM
Anyone running only Malwarebytes for security
by Donald - 11/12/19 05:07 PM
smokinhiro, iamrobertkrogh, Hombre909, DeLong, Scuder
69842 Registered Users
103 registered members (AndyB, 1978elcamino, Anduril, andyd, alarmguy, 2004tdigls, 8 invisible), 2,130 guests, and 19 spiders.
Topics297,344
Posts5,113,603
Members69,842
Most Online3,589
Nov 2nd, 2019
how to deep clean calipers? baked on brake dust #5259091 11/05/19 11:45 AM
B
bionictony Offline OP
B
calipers not attached. these are toyota calipers. is there a coating on the calipers or is it raw cast metal? i have used a stainless wire brush, gunk engine foaming degreaser, and brake parts cleaner, and simple green. cant get the baked on brake dust in the inside calipers. they are not from the rust belt so no rust at all. are there other solvents i could try? i want to clean as much as i can before taking out the pistons to rebuild.
07 Corolla LE (1ZZ-FE)
13 Venza (2GR-FE)
14 Camry SE (2AR-FE)
oil quart stash: about 100 quarts
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5259107 11/05/19 12:05 PM
T
tundraotto Online Content
Online Content
T
Take to a shop with a parts washer.
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5259138 11/05/19 12:40 PM
R
RamFan Offline
R
Meguiar's Ultimate Wheel Cleaner and elbow grease.
Since you're doing a rebuild, maybe a dunk in Chemtool is in order?
18 Giulia Ti Sport Q4
  • 2.0T I4 - 19k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 65k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5259167 11/05/19 01:37 PM
sasilverbullet Offline
Spray carb cleaner works also, use gloves in a well ventilated area.
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Ceratec & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 5W-30 & WIX
02 Chevy 5.7L van-GTX HM 10W-40 & WIX
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5259246 11/05/19 03:56 PM
K
kstanf150 Offline
K
Easy off oven cleaner
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5259273 11/05/19 04:45 PM
R
Railrust Offline
R
Sand blast them.
Re: how to deep clean calipers? baked on brake dust [Re: Railrust] #5260562 11/07/19 08:28 AM
code5coupe Offline
Originally Posted by Railrust
Sand blast them.
My thoughts exactly. Cheers1
1996 Corvette LT4
2012 Grand Cherokee SRT
Re: how to deep clean calipers? baked on brake dust [Re: bionictony] #5260716 11/07/19 11:27 AM
N
nthach Offline
N
Media blast or hot-tank. If you can get the old school Chemdip that smells like death and will dissolve anything non-metallic that can work as well.
Some motorcycle wrenches even use Lestoil to soak parts, which is the same thing as Pine-Sol before it was reformulated to not have pine oil or solvents.
