Originally Posted by Cujet
Originally Posted by panthermike
Well I took it in I had it checked over by local shop. They could verify my concerns but were unable to find any actual issues. Also they're scanning included a cylinder contribution test that turned up nothing everything appeared "normal", no misfires detected.
I was actually really hoping there would be as this means my issues are not related at all. I don't really have the time or the money to go start chasing these issues. I may need to seriously consider getting into something else, at least that's seems like a reasonable option at this point.
My airplane sometimes runs smooth, and at times the instrument panel shakes like the engine is running rough. Come to find out, the engine mounts are sagging a bit and the vibration transfer is "sensed" as a problem. As the engine mount sags, the exhaust pipe will sometimes touch the cowling during turns and "buzz" like crazy. Leading to a real feeling of unease!
Yet the only real problem is a couple of rubber donuts that are softer than before.
I don't have any idea if your truck is going to be reliable or not. But my guess is that you are trying to trouble shoot the wrong issues. I own a 2009 F150 with the 3V 5.4L and have followed your posts with interest. Mine is not silky smooth at idle, and does shake on startup. It does have that minor "rattle" that is audible when driving slowly next to a concrete wall. But at 140K miles, it's still running strong and takes all the abuse we throw at it.
That rattle or knock is often just the camshaft drive dowel moving a few thousandths in it's slot. A very common issue that is not a major problem. 10W-40 oil does help calm this noise down.
I wish you luck, and it's my guess that things are probably OK. But I'm not there to experience it.
https://www.youtube.com/watch?v=O7GcqtNTMqQ
Thanks for the insight cujet. I'm familiar with phaser issues (video linked) but that's not the issue with mine. It actually doesn't have startup noise anymore as the phasers are new.
Mounts are something I have not checked! If I'm chasing the wrong issues, which ones should I be chasing? Or don't chase at all?
