- Joined
- Nov 29, 2009
- Messages
- 7,262
I have a Honda gx390 pressure washer and I'm pretty sure it's been a year since I've used it. I fired it up today to make sure it still started and it fired right up! Other engines if I did that would probably need the carb cleaned.
Opinions? No fuel stabilizer was used. All I did was turn the fuel valve off. Unless this is the reason why. After a couple weeks the fuel probably evaporates in the carb.
