That new manual transmission fluid feeling
Maryland
I have a manual transmission Tacoma with the r156f transmission. Seems like a lot of people with this transmission and the previous generation 155f(2005-2015 models) complain about 2nd gear and 3rd gear engagement being best described as notchy. So far I've tried redline mt-90, motul 300v and currently on liquimoly 75w90 gf-4 fluid. Anytime I change the fluid the transmission shifts sooo smooth and beautifully that I don't want to stop driving. After a couple hundred miles, which I'm assuming is once the oil breaks in, that beautifulness disappears and I'm back to the notchy shifts. Any ideas why this happens and is there a way of addressing it?
I believe the Motul 300v and Liqui-Moly are both GL-5 especially the LM because they do not sell a 75w-90 GL-4 in the US market.
Why not try a 75w GL-4? NOT a synchromesh variety...but a REAL 75w GL-4 only gear oil?
I'm personally one of those guys who believes heavier oils protect better, I forget the exact term people label us on here, but yeah I'm one of THOSE guys
Anyways, OEM specs 75w90, and I don't see my self going lower unless it will actually be beneficial other than just gaining a fraction of a MPG. I doubled checked, both LM and Motul do make GL-4 variants. Correction: the motul was a gear 300, not a 300V. One of the reasons I actually tried the LM was because it's not a full synthetic. As GL5 is too slippery for transmissions I thought maybe the synthetic GL4 oils I was trying were maybe too slippery causing the undesirable shifting characteristics. The LM product I got is supposed to be a semi-synthetic(however way they're defining it) and it was a let down too. Atleast at $10 a quart I dont feel terrible with my experiment.
Redline is a REAL GL-4 only gear oil isn't it?
https://www.redlineoil.com/mt-90-75w90-gl-4-gear-oil
Honestly if none of those fluids has addressed the feeling your having nothing is going to IMO. I can't explain the 'feeling great for a while' symptom though.. haha
I'm one of those too. We're "thickies" haha!
My 2004 Honda S2000 has a finicky 6 speed that liked to grind going into 2nd. Royal Purple Syncromax tamed it.
