Shell Rotella Gas Truck 0W-20 UOA Honda Civic
by Davejam - 06/04/20 11:50 AM
replacement tires for 2013 vw passat 2.5
by jstert - 06/04/20 11:04 AM
Communication with Castrol
by BTLew81 - 06/04/20 10:47 AM
How Often Do You Check Your Oil?
by Gebo - 06/04/20 10:04 AM
Slightly OT....shelf life of "boxed" oil containers
by nascarnation - 06/04/20 10:00 AM
choose tire
by John_Conrad - 06/04/20 09:57 AM
J35Y
by tbm5690 - 06/04/20 09:26 AM
Need help with CV Joint grease, very limited choices
by leoblack9 - 06/04/20 08:41 AM
Amsoil 0W20, 2016 Honda Accord V6
by Eddddd - 06/04/20 07:59 AM
New to me Ford Escape
by krz - 06/04/20 06:57 AM
Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
89 registered members (16HC, agarb, 2015_PSD, ABN_CBT_ENGR, 53' Stude, 8 invisible), 2,023 guests, and 105 spiders.
Topics306,132
Posts5,288,087
Members71,604
Best Universal Brake Grease #5258278 11/04/19 12:22 PM
Dinodon Offline OP
Looking for recommendations for a Grease I can use on Calipers and Drum Hardware like Backing Plate contact points, Star Wheels too .
Super Lube some say.
Re: Best Universal Brake Grease [Re: Dinodon] #5258283 11/04/19 12:31 PM
K
kschachn Offline
K
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Best Universal Brake Grease [Re: Dinodon] #5258315 11/04/19 01:17 PM
Q
Quest Offline
Q
There's no "BEST UNIVERSAL BRAKE GREASE", period.
seasoned/experienced mechanics should have 2 or more different types of grease for brake jobs:
Sylglide or similar for guide pins and bushings; high temp copper antiseize for drum brake backing/metal-to-metal sliding point lubrications.
Someone would also recommend using something like permatex purple synthetic ceramic grease for brake pad backing lube (I do that too), while others would recommend high melting point anti-seize (that works also, apply sparingly).
I've seen some ole mechs applying bearing grease on guide pin bushings before, and the liability concerns are on them (and not me).
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Best Universal Brake Grease [Re: Dinodon] #5258317 11/04/19 01:19 PM
Dinodon Offline OP
I used marine grease before on Drum stuff. seemed to work on Light duty applications.
Re: Best Universal Brake Grease [Re: Dinodon] #5258343 11/04/19 01:46 PM
Dave9 Offline
Raybestos Silicone Paste, DBL-2T, followed by 3M Silicone Paste 08946
Re: Best Universal Brake Grease [Re: Dinodon] #5258352 11/04/19 02:04 PM
supton Online Content
Online Content
Honda M77 moly assembly lube for pad ears and other points of metal on metal contact like that. Sil-glide for pins. Anti-seize on the rim where it will sit on the hub (avoiding threads), but I'm guessing that may not be a problem where you live... maybe... but sure is here.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Best Universal Brake Grease [Re: Dave9] #5258361 11/04/19 02:20 PM
diyjake Offline
Curious why Raybestos Silicone Paste over 3M, just because it's cheaper?
Re: Best Universal Brake Grease [Re: Dinodon] #5258367 11/04/19 02:33 PM
CharlieBauer Offline
Permatex Silicone Ceramic Extreme (Red) can be used on everything.
Permatex Ceramic Extreme (Purple) may last longer but to be safe should not be used on parts that contact rubber / plastic. For those areas, use a silicone grease such as Motorcraft XG3 or the 3M Silicone Paste.
Btw, Rockauto have good prices on Permatex so adding it to an existing order can get you a nice deal. And if you're only doing the occasional job, then the sachets from the auto store have enough.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Best Universal Brake Grease [Re: Dinodon] #5258400 11/04/19 03:19 PM
A
atikovi Offline
A
[Linked Image from images-na.ssl-images-amazon.com]
Silicone so it's safe on rubber. Ceramic so it's high temperature tolerant. Wouldn't use anti-seize anywhere near brake parts that get hot.
Re: Best Universal Brake Grease [Re: Dinodon] #5258473 11/04/19 04:36 PM
The Critic Online Crying
Online Crying
The CRC brake grease is probably the closest product to a "universal" brake grease, but I have seen it gum out and dry out occasionally.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Best Universal Brake Grease [Re: diyjake] #5258614 11/04/19 07:37 PM
Dave9 Offline
That and PTFE. As far as caliper slider pins, once they are properly cleaned and lubed with this, it's unusual to ever need lubed again unless it's a severe (not just heavy duty) use, but of course pad rails and other exposed areas will need fresh lube when they are cleaned or replaced.
Re: Best Universal Brake Grease [Re: Dinodon] #5258623 11/04/19 07:45 PM
T
tundraotto Offline
T
What happened to people using the copper anti seize by CRC etc.....always worked great for me, but I am no mechanic.
Re: Best Universal Brake Grease [Re: Dave9] #5258992 11/05/19 10:20 AM
diyjake Offline
Thanks! I have been using Sil-Glyde for pins but I am not impressed with it so I was going to use 3M Silicone but might give DBL-2T a try. Do you use DBL-2T just for pins or metal to metal as well? I am currently using 3M 08945 Copper Anti Seize Brake Lube for metal to metal.
Re: Best Universal Brake Grease [Re: Dinodon] #5259129 11/05/19 01:29 PM
N
nthach Offline
N
My current MO is Toyota Rubber Grease or Dow 111 on any rubber to metal contact like slide pins. For metal-on-metal I've been using the older version of Permatex's Silicone Brake Lube. While you can get away with the green/purple(or lilac/lavender) Permatex greases for shims, the caliper boot is often times the only defense a brake piston has and breach that, good bye piston.
I only use copper anti-seize(Never-Seez/C5-A) for drum brake backing plates/hardware and when Molykote M7439 is called for.
Re: Best Universal Brake Grease [Re: Dinodon] #5259931 11/06/19 02:24 PM
diyjake Offline
How does 3M or Raybestos Silicone Paste DBL-2T hold up on caliper pins? The heat doesn't affect it?
