I purchased a tube of Mazda touch-up paint and the applicator is beyond horrible and totally unusable. The applicator is a thin metal tube with a spring-loaded metal ball. Its similar to a mechanical pencil tip but with a ball point at the end.
After adequate shaking followed by dozens (if not hundreds) of attempts on a test area under the hood, the paint will not flow adequately. The ball point can actually damage the surface. I tried every conceivable technique to make this thing work.
Pure JUNK! If you purchase this, just puncture the can in a way you'll be able to plug the hole and just use an art brush to apply the paint. -Trust me. The built-in applicator is totally useless.
Ray
Ray
