Forums Migration
Please read this thread
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
Running 40 PSI vs 35
by Mr_Luke - 07/07/20 03:05 PM
Kidney Filtration-Secondary Effects???
by TravlinTech - 07/07/20 02:41 PM
When to replace mower deck?
by supton - 07/07/20 02:39 PM
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
107 registered members (55hambone, 14Accent, Anthony, Astro_Guy, AlienBug, 14 invisible), 1,950 guests, and 21 spiders.
Topics307,572
Posts5,313,296
Members71,876
Measuring and adding fuel treatment #5257586 11/03/19 02:23 PM
B
bcwang Offline OP
B
What tool do you guys use to accurately measure and pour into the gas tank without a mess, a fuel treatment like redline si1 at maintenance doses? Something you can carry in the car that doesn’t become a hazard now that you’ve put fuel treatment in it.
It would be nice if redline si1 or other products where you only use a small part of the bottle had a built in measuring and dispensing spout making this easier.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257588 11/03/19 02:25 PM
J
JLTD Offline
J
Isn't it something like one bottle per tank full?
Lates.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257601 11/03/19 02:38 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
SI-1 used to be marked for 10 gallon maintenance dose increments. They did remove that I recall....
Honestly I just go by the less is more philosophy, and err on the side of less.
You could get some sort of measurement cup and pour appropriate quantities out, mark the bottle, then put it back in. Assuming you’re going to consistently use that add, and the bottle doesn’t change, no big deal. Pour half the bottle out, mark it, then use a ruler to mark the other appropriate points.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257614 11/03/19 02:59 PM
T
toad Offline
T
I use a metal measuring tablespoon. If you have steady hands it is easy to pour out a tablespoon or two and the spoon fits nicely into the fuel inlet of our cars. I can get all but maybe a couple of drops into the tank without spilling any. Measuring tablespoons come in a number of different shapes, so pick one that will mate with your inlet. I think gas tank inlets are standardized, so this should work on just about any make and model.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257619 11/03/19 03:14 PM
Yah-Tah-Hey Offline
I found a PVC measuring cup at Bomgaars (home and ranch) used by the ag people for mixing whatever it is they spray. Graduated in ounces. Use it to dose each tank of fuel with Techron and A StayBil product. Seems impervious to additives. Little pricey though. Seems all that ag spray equipment is $$.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257627 11/03/19 03:28 PM
I
incognito_2u Offline
I
I use an old, empty bottle of "Stabil" fuel stabilizer (The one with a ounce incremented measuring device built into the container that you "squeeze")
I'm able to accurately measure the amount needed in relation to the fuel I used.
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Measuring and adding fuel treatment [Re: bcwang] #5257678 11/03/19 05:01 PM
R
R_W_M Online Content
Online Content
R
Ditto on the Stabil bottle. Quick accurate measurement and no mess.
2005 Ford Five Hundred 108 K Mi.
2009 Subaru Forester 23 K mi.
Re: Measuring and adding fuel treatment [Re: bcwang] #5257779 11/03/19 07:55 PM
J
JimPghPA Offline
J
McMasterCarr sells a 100 mL graduated cylinder made from translucent white plastic that is very good for measuring additives like Redline SL-1 down to the mL.
I use to add Redline SL-1 to the gas-tank before each fill-up. If I remember correctly the recommended dose on the Redline bottle is 4.45 mL per gallon of gasoline.
McMasterCarr has a web site. You can order from them. There shipping is very fast and low cost. They have a special deal with UPS.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Measuring and adding fuel treatment [Re: bcwang] #5257782 11/03/19 07:59 PM
J
JimPghPA Offline
J
Store the graduated cylinder upside down in a plastic bag with no holes in it after you use it. Redline Sl-1 is extremely hydroscopic. It will pull water right out of the air and if stored upright there will be some water in the cylinder the next time you go to use it if stored upright.
JimPghPa
Re: Measuring and adding fuel treatment [Re: JimPghPA] #5257853 11/03/19 09:58 PM
Malo83 Offline
Who measures! i just pour the whole bottle in and fuel up, i err on the most is best. Cheers2
Re: Measuring and adding fuel treatment [Re: bcwang] #5257915 11/04/19 12:04 AM
CharlieBauer Offline
No need for maintenance dose if you use top tier especially Costco which is usually the cheapest.
Otherwise, I typically buy fuel system cleaner bottles that treat my fuel tank size.
On the occasions where I have bought the "treats 35 gallons" Gumout All In One Complete, the tool I used to measure splitting the bottle between two vehicles was my eyes.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Measuring and adding fuel treatment [Re: bcwang] #5258192 11/04/19 10:32 AM
M
MarcS Offline
M
I use s twin neck dispensing bottle. Its a 16oz bottle with a 1oz dispenser. You squeeze the bottle, it fills the dispenser.
Re: Measuring and adding fuel treatment [Re: bcwang] #5260007 11/06/19 03:58 PM
DGXR Offline
I used an empty sta-bil bottle previously, which works good. But I don't like carrying around an entire quart of additive. I went to a local plastics shop (Tap Plastics, they sell sheet acrylic, laminates, plastic strands, buckets, bottles, containers galore, it's really cool) and found some small 5-oz HDPE plastic bottles with lids that seal up well, I think they were $0.50 apiece.
Here's the webpage: Tap Plastics - Plastic Bottles with Lids
Anyway, I used the sta-bil bottle to measure out 1oz increments and marked 1oz lines on the side of the small bottles. Now I just carry asmall bottle with me in the car or truck all the time and refill as needed.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
2003 Honda XR400R
1999 Yamaha YZ400FL
Re: Measuring and adding fuel treatment [Re: bcwang] #5260200 11/06/19 07:51 PM
B
bcwang Offline OP
B
The plan was for si1 maintenance doses but now it’s no longer recommended to use that way? Then I may not pursue this further as that was what kicked off the idea.
I think the stabil bottle idea works well. That is the ideal bottle for this it seems. All self contained, easy to measure, easy to pour in the gas tank.
Re: Measuring and adding fuel treatment [Re: bcwang] #5260332 11/06/19 10:55 PM
R
red7404 Offline
R
i use a sta-bil bottle. i add TC-W3 1 oz to 5 gal of gas
