Originally Posted by kschachn
Originally Posted by TiredTrucker
Only 7 states mandate the use of ethanol in all gasoline. That leaves 43 that don't. If ethanol free is not readily available, the is due to either one's state legislature or the local retailers. It is not the EPA, the Corn Lobby, or whatever. It is a problem in one's own state.
Do you have me on block or do you just choose to continue to post incorrect information?
Nope. Not on block.
This was an article from 2015. Nothing much has changed in terms of ethanol requirement by Feds. Any nonsense is mostly state directed. Some states support and have incentives for ethanol blended fuels, but that doesn't mean they ban ethanol free fuels, that is, except for 7 states. That is down from 9. Some states, especially Maine, have been trying to pass legislation to ban all ethanol blended fuels in the state. If only 7 states mandate ethanol blended fuels, and a couple that did have since rescinded that position, and some states are actually considering banning ethanol blended fuels, then that by default means the EPA has no say in mandating ethanol blended fuels by each state. Only on a overall national level that ethanol be used. How it is used, or if it is used, is up to each state.
https://www.greencarreports.com/new...line-only-seven-states-require-e10-blend
And from another source that delves a little deeper and verifies the above link.....
https://www.hemmings.com/blog/2015/...in-your-fuel-fewer-than-you-might-think/
You can believe whatever floats your boat and bury your head in a bucket of..... whatever.
Nope. Not on block.
