First post. I found sandy oil in my intake plenum changing spark plugs. Immediately changed oil and took sample mid drain stream with Wix Napa kit. I expected the report to show high wear and silica... Also using k&n air filter. I believe the dealer failed to seat the rubber intake tube to the throttle body when replacing leaky oil cooler a year ago. Van has had nothing but 5w20 Pennz Plat since free first change at 2k. Filters have been wix/napa 10010 or fram tg or xg or mopar.
