WiFi Network Monitoring Tool
by ZeeOSix - 06/06/20 09:47 PM
a sad day for our family
by miden851 - 06/06/20 09:26 PM
pressure starts up first try after not used for 6 months
by motor_oil_madman - 06/06/20 08:50 PM
Any Recommendations For LED Shop Lighting
by walterjay - 06/06/20 08:36 PM
Which brake pads for towing?
by pburchett - 06/06/20 08:27 PM
supertech 0w16 $11/ 5 qt
by eljefino - 06/06/20 07:55 PM
Pennzoil 5W-20 HM Ecobox? $2.27????
by Jackson_Slugger - 06/06/20 07:50 PM
Fluid for Jeep electric-boosted spower steering?
by Jeffrey Behr - 06/06/20 06:33 PM
Bottom grill hitting radiator fan
by dan765 - 06/06/20 06:26 PM
Unknown mystery oil
by Zgrant231 - 06/06/20 06:23 PM
Paint Protection Film (PPF)
by HDoilDude - 06/06/20 05:40 PM
Old RedMax EBZ8001
by BISCUT - 06/06/20 04:57 PM
ATF as general purpose oil?
by buck91 - 06/06/20 04:29 PM
Silicone vs fumed silica?
by buck91 - 06/06/20 04:24 PM
e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Jeancando, SkulltulaHouse, geekofband007, jproposki, 1mzsludge
71625 Registered Users
80 registered members (4WD, aquariuscsm, Alfred_B, 5AcresAndAFool, Astro14, 2015Corolla, 10 invisible), 1,560 guests, and 33 spiders.
Topics306,318
Posts5,290,076
Members71,625
Storing small engines for the winter... #5255250 10/31/19 05:31 PM
W
whatplsty Offline OP
W
I always thought that I am supposed to store my small engines with no fuel in them. I read the directions on the fuel stabilizer container and it said to store the small engines with stabilized fuel in them. Which is correct?
Re: Storing small engines for the winter... [Re: whatplsty] #5255258 10/31/19 05:39 PM
I
Imp4 Offline
I
The fuel stabilizer folks will always recommend that you use their product, so there's that....
Me personally, I've never experienced a difference between storing with a dry fuel tank versus with stabilized fuel.
Others will certainly profess differing opinions...
Re: Storing small engines for the winter... [Re: whatplsty] #5255263 10/31/19 05:44 PM
MrMoody Offline
Cheaper to store them dry, and it always works ...
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Storing small engines for the winter... [Re: whatplsty] #5255272 10/31/19 05:51 PM
demarpaint Offline
You'll hear a variety of storage methods. I store my OPE with stabilized fuel and a bit of MMO or TCW3 mixed into the fuel. I run the engine until its hot with the "fuel mix", fog it, change the oil, and put it away. "I've" had better luck doing it this way vs. running the gas tank dry. This applies to engines that I plan on storing up to a year +/-.
God Bless Our Troops
Re: Storing small engines for the winter... [Re: whatplsty] #5255274 10/31/19 05:51 PM
J
JC1 Offline
J
I've done it both ways and It didn't make a difference for me. I usually pour some extra stabilizer right into the tank of the Mower or snowblower and let it run for a few mins before shutting off for the winter. I've also done the fogging oil in the cylinder as well.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Storing small engines for the winter... [Re: demarpaint] #5255312 10/31/19 06:47 PM
U
Ursatdx Offline
U
That's my way of winterizing. Stabil/2 stroke(a bit) and full tank.
I've learned the hard way that what you think is an empty carb is really not empty.
The residual fuel can dry and leave a small dry film that can fill the microscopic
ports that small engine carbs have. IMO the 2 stroke lubricates and protects from any build up
of crud.
I'll fof if I know it will be more than 6 months between uses.
YMMV.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Storing small engines for the winter... [Re: whatplsty] #5255327 10/31/19 07:06 PM
F
fdcg27 Offline
F
In my experience an engine stored dry will be easier to bring back to life than one stored wet.
Also, fuel stabilizer products do nothing.
Worst case scenario, you give the thing a couple of shots of either in the spring and it bursts into life with no problems thereafter.
And, no, either used with a modicum of sense won't harm the engine at all even though some poster will swear that their grandpa's neighbor's cousin's friend blew up a perfectly fine engine using it.
18 Accord Hybrid 30K HGMO 0W-20
17 Forester 36K VME 0W-20
12 Accord LX 115K SSO 0W-20
09 Forester 119K M1HM 5W-30
96 Accord LX 104K T5 10W-30
95 318i
Re: Storing small engines for the winter... [Re: whatplsty] #5255345 10/31/19 07:22 PM
T
tundraotto Offline
T
I don't use ethanol gas in any OPE and always use a fuel stabilizer. I never have a problem anymore. With carbs or fuel lines.
Re: Storing small engines for the winter... [Re: whatplsty] #5255360 10/31/19 07:49 PM
A
ammolab Offline
A
I put stabil in the remaining fuel and run them dry. No problem so far.
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Storing small engines for the winter... [Re: whatplsty] #5255379 10/31/19 08:18 PM
Snagglefoot Offline
I try to run the tank low and throw in a bit of fuel stabilizer. In the spring I buy fresh gas and fill the tank. I then give it a couple choked pulls. If it doesn’t start I give give it a shot of starter fluid aimed at the air filter and it will take off and run well once the fresh gas hits the carb.
I fog my boat motor but don’t bother fogging the lawn mover. My backup lawnmower is 25 years old and has never been fogged. Still runs like a top, However, it’s pretty dry out here.YRMV. smile
If you want the job done right......do it yourself.
Re: Storing small engines for the winter... [Re: whatplsty] #5255529 10/31/19 11:25 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Honestly I’ve never had fuel or carb issues (knocking on wood) with quality OPE.
I do run stabilizing additive and a tiny splash of TCW-3 in my E10 pump gas... and try not to inventory too much.
When able, I’ll run them dry. Dry is probably relative, Ive never pulled the carb to see if it’s truly out of gas. Ive always wondered if doing thst leaves just enough that it can evaporate and leave residues, while if more gas was in the bowl, it might not evaporate out...
Regarding fogging, I’ve bought fogging spray with the best of intentions. And come the end of the season, I either don’t remember, don’t have time, etc. is my stuff worse for wear? Not that I can tell. Maybe if it was stored outdoors it would be an issue. It’s not.
Is it best practice? Guess so...
Re: Storing small engines for the winter... [Re: demarpaint] #5255605 11/01/19 05:41 AM
L
Linctex Offline
L
. I store my OPE with stabilized fuel and a bit of MMO or TCW3 mixed into the fuel. .
This has given me the best results. Some rubber parts are susceptible to "drying out" (getting hard) when dry, it seems.
Re: Storing small engines for the winter... [Re: whatplsty] #5255611 11/01/19 05:52 AM
L
Lubener Offline
L
Best to run them dry but I always add Stabil in the gas can prior to filling so it's no big deal if I leave some fuel in the tank. I won't leave untreated fuel sit in the tank for the winter.
The "thinking" man's friend.
Re: Storing small engines for the winter... [Re: whatplsty] #5255815 11/01/19 10:14 AM
K
Kamele0N Offline
K
This year I discovered this fuel in my local hardware store (Bauhaus)
https://aspenfuel.co.uk/
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Storing small engines for the winter... [Re: whatplsty] #5255823 11/01/19 10:18 AM
W
WobblyElvis Offline
W
I don't do anything, I put the lawnmower in the shed and it starts with about 5 pulls in the spring. I did have a problem once when I used gas that was 15 years old.
