Originally Posted by Quadrasteer
No question about running the engine under a load, just about going by older directions, seems it would clean better at a higher idle but probably taking a chance. What do you think about my idea of shutting it down, waiting a while to soak in and then finishing the the run as directed? I also might try and look into the oil pan and use a solvent gun to clean it if needed......or not.
It's a 15 minute flush, run it for 15 minutes and drain the oil. As Molakule stated it thins the oil, high rpms with solvent thinned oils are not a good idea, that's why it is called a 15 minute "idle" flush. Turning it off to let it soak in, isn't going to matter. Again, run it as directed. If you're looking for a longer flush which will be exposed to the normal cycles of an engine and stay in the sump for an extended period of time, try Rislone's flush after the Amsoil flush. Allow a full OCI with no additives between products. It took a long time to get the engine dirty, you're not going to safely clean it up in 15 minutes or one OCI. If it were mine I would ditch the idle flush idea all together, and use a slow cleaning product.
