I'm running a Dell all-in-0ne desktop computer with a terabit HD. I wonder if it can be upgraded with an SSD drive? I only use about 1/10 the capacity of the present HD. Just thinking of the future since the present computer is 5 years old. Ed
We are in the process of changing out HD for SSD in our POS machines. We simply had to clone the original HD and install the new SSD and it was good to go. It is a noticeable upgrade in speed and most certainly in reliability.
You only need to buy a 2.5 inch drive, no adapter or mounting parts.
If your original 1 TB drive is not full and you don't intend to fill it you can use Windows to resize to a smaller partition (this takes a long time) then use a smaller replacement drive.
After copying the data to the new drive (using disk cloning software and a USB to SATA adapter), take the computer apart and R&R the drive.
Remove the stand and the plastic back cover (After releasing the latches at the bottom, Dell suggests prying around the sides starting at the gap for the DVD drive) then the metal cover on the right side as you look at the back. Pull the original drive with its blue frame then remove the drive from the frame and install new one.
Even if it is a bit more difficult to get to the HDD, I would still do this upgrade. Going to an SSD is the biggest and cheapest performance gain you will ever see and actually enjoy every time you fire up the computer and use it, not just some artificial benchmark numbers that don't mean much in real use.
You can get a 240GB SSD for about $30 all day long. It will rejuvenate your machine 100% guaranteed.
Originally Posted by bobdoo
Double-check that you don't need a SATA power adapter.
You won't need one here. This all-in-one PC is built a lot like a laptop where the SATA drive plugs directly into the motherboard with no cables. It doesn't look like there is a place for two drives.
Looks easy on that video. Buy a 250gb SSD and toss it in there with another stick of RAM. But I'd reinstall Windows 10 with a thumb drive and start from scratch. Can use a SATA to USB adapter to get your files off the old hard drive and drag and drop.
I do this for a living for a large corporation, those old computers fly with a new SSD, 8gb of RAM, and fresh Windows 10.
I would recommend updating the bios firmware to the latest version on a dell before you do the swap.
Also I'm not a fan of cloning drives, good to start fresh, it would be a good time to set the bios to UEFI if supported, and do a clean install of windows 10 from a usb key.
