belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
26 registered members (BlakeB, blufeb95, ArrestMeRedZ, carlprop, Black_Thunder, Bailes1992, 2 invisible), 1,216 guests, and 24 spiders.
Topics301,895
Posts5,204,861
Members70,798
20 wt and 30 wt oils #5254139 10/30/19 11:54 AM
M
mobilaltima Offline OP
M
What are my option regarding thick 20 wt and thin 30 wt oils for the 3.7 Duratec V6 in my F150?
Also, so I dont have to make a separate post in the oil filter section, would the OEM Motorcraft FL500S be the best filter to use? Didnt it have tearing issues?
What is the bypass psi on the FL500S?
Or should I use a Napa Gold 7502, which crosses to the FL500S?
The 7502 has a 22 psi bypass.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254143 10/30/19 12:01 PM
O
OVERKILL Offline
O
If you want a thin 30, M1 AFE 0w-30 would be a good fit. Do you or heavy haul with it? Best bargain for a premium filter is the FRAM Ultra IMHO.
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254194 10/30/19 01:11 PM
P
paoester Offline
P
Thinnest kv100 5w30 I've seen is Pennz Platinum 5w30 at 9.8 cSt.
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254224 10/30/19 01:44 PM
Z
ZeeOSix Offline
Z
Per Purolator who makes Motorcraft oil filters, the FL-500S bypass valve is set to 17+ PSI (at least back in 2011). Who knows if it's been changed since then (probably not).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2307599
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254265 10/30/19 02:35 PM
P
paoester Offline
P
The good news is, if using a Motorcraft filter, the bypass won't open due to the big hole in the media. I guess thats good anyway.
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254282 10/30/19 02:56 PM
K
ka9mnx Offline
K
Been using Motorcraft filters on Ford's for almost 50 years. They are fine.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254288 10/30/19 03:00 PM
K
ka9mnx Offline
K
I'm using 5w-30 SupetTech synthetic in my Ranger that spec's 5w-20. You would have to find the HTHS of the oils you want to use to find if they are thick or thin. But that is not easy with most oil companies. The 5w-30 I use has an HTHS @150c of 11.2.
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254297 10/30/19 03:15 PM
T
Tdog02 Offline
T
5w30 all day here in Texas, and in your neck of the woods also. The motorcraft can filters are pretty solid. Used with a reasonable OCI you should be fine there. But between your choices you could go off of lowest price.
09 Venza 2.7 114k 5w-30 Qsud
16 F150 2.7TT 71k 5w-30 Magnatec
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254429 10/30/19 06:08 PM
M
M
I think Ill go with Pennzoil Platinum 5W30 and either a Motorcraft filter or Fram Ultra at 5k intervals.
Will the Fram XG10575 bypass of 16-28 psi suffice?
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254603 10/30/19 10:34 PM
T
tiger862 Offline
T
Why not go with Valvoline Daily Protection 5w20? It is a blend that is little thicker than Synthetic and Ford uses a blend for most vehicles. Timing chain wear is caused from excessive amount of miles between oil changes or a design flaw that a "thicker" oil will hide the symptoms of a timing chain going bad. Many module Ford's are over 200k on 5w20 conventional and you claim 5k oil changes which is the best you can do to prevent timing chain wear. 3.7 was ran from Ford on synthetic blend.
Motorcraft filter
Tiger862
2018 Grand Caravan
Re: 20 wt and 30 wt oils [Re: paoester] #5254627 10/30/19 11:37 PM
ChrisD46 Offline
+1
'17 Hyundai Sonata 2.4L GDI 5W20 QSUD / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254687 10/31/19 04:43 AM
D1dad Offline
I’m using PPHM in my 08 impala 3.9 and it’s developed a tick of sort that wasn’t there on QSUD. On top of that it burned a half qt in 1100 miles.
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254694 10/31/19 05:02 AM
K
ka9mnx Offline
K
Motorcraft filter...
Re: 20 wt and 30 wt oils [Re: ka9mnx] #5254781 10/31/19 06:58 AM
K
kschachn Offline
K
I find the promotion of Motorcraft (and Purolator) filters interesting, I use neither in any of my cars, but why would anyone use a filter that has had a demonstrated history of failure on here?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: 20 wt and 30 wt oils [Re: mobilaltima] #5254788 10/31/19 07:00 AM
A
alarmguy Offline
A
Any 5w30 oil is good
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
