Interesting read
by double vanos - 02/26/20 10:51 AM
2010 Honda Element 127K miles valvetrain picture
by SLO_Town - 02/26/20 10:01 AM
Anyone Used a Sea Sucker Bike Rack/Mount?
by jcartwright99 - 02/26/20 09:46 AM
8 passenger vehicle typically 5 for <=$15k
by madRiver - 02/26/20 09:27 AM
RON Octane Gasoline rating
by Building3 - 02/26/20 09:26 AM
Who makes Canadian Supertech?
by Patman - 02/26/20 09:08 AM
Benefits of a hard break-in discussion
by buster - 02/26/20 08:54 AM
2004 Cavalier 2.2L Oil Change Interval?
by Bob5150 - 02/26/20 08:44 AM
Amazon Redline 5w30 $41.99/gal
by SubieRubyRoo - 02/26/20 08:00 AM
Possible Clearance Score ?? Royal Purple 5W30
by GMguy84 - 02/26/20 04:34 AM
1994 Buick Century 63k miles pics
by MuzzleFlash40 - 02/26/20 04:10 AM
Oils for old engines
by puma4440 - 02/25/20 08:18 PM
Do you still use liquid and paste sealants
by WhyMe - 02/25/20 08:16 PM
VW dealer hilarity - window tinted the wrong car.
by pezzy669 - 02/25/20 07:53 PM
New style Goodyear Duratrac
by NHRATA - 02/25/20 07:44 PM
Need oil additive advise for replacement engine.
by 13Track38 - 02/25/20 07:18 PM
New member with UOA to share
by JamesGames - 02/25/20 07:10 PM
When do you do DIY?
by BMWTurboDzl - 02/25/20 06:47 PM
Jimbobert56, Ollie_B_2000, akarip, BJD2020, ToyTaco2002
70803 Registered Users
105 registered members (1978elcamino, andreigbs, AlaskaMike, ArgleBargle, 28oz, 928, 9 invisible), 2,113 guests, and 19 spiders.
Topics301,947
Posts5,206,080
Members70,803
Page 1 of 4 1 2 3 4
Best Silicone Type for Caliper Pins #5252960 10/29/19 10:34 AM
P
painfx Offline OP
P
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5252963 10/29/19 10:37 AM
demarpaint Offline
I've had good luck with Sil Glyde.
God Bless Our Troops
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5252964 10/29/19 10:42 AM
The Critic Online Crying
Online Crying
The 3M Stuff is okay, but the non-silicone Toyota Pink grease is better.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5252982 10/29/19 11:01 AM
N
nthach Offline
N
3M silicone or Dow 111 if the OEM calls for silicone grease.
Sil-Glyde is IMO closer to the red glycol-based grease Toyota and Subaru use despite the fact it has a little castor oil in it. I use the Toyota stuff for things that need that grease.
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5252987 10/29/19 11:04 AM
K
kschachn Online Content
Online Content
K
Sil-Glyde doesn't have any silicone in it, correct?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Best Silicone Type for Caliper Pins [Re: kschachn] #5252997 10/29/19 11:13 AM
P
painfx Offline OP
P
How do you know it doesn't have any silicone in it?
Re: Best Silicone Type for Caliper Pins [Re: The Critic] #5252998 10/29/19 11:14 AM
P
painfx Offline OP
P
If you had the choice between the 3M and Sil-Glyde, which would you grab to lube the slide pins?
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253000 10/29/19 11:20 AM
SLO_Town Offline
You should consider this. I've used it for years.
Scott
https://www.amazon.com/ATE-700015-P...d=1572369468&s=automotive&sr=1-1
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253013 10/29/19 11:33 AM
Online Crying
Scott
Didn't know this stuff could be used for pins - MB spec'ed it for the pad ears only. I think I have a big tube of ATE Plastilube (under the MB label). Do you want it?
Neither, but if I had to, 3M.
What did you use when you were a tech?
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253015 10/29/19 11:33 AM
Dave9 Offline
3M or its equal for lower cost is Raybestos DBL-2T
https://www.amazon.com/Raybestos-DBL-2T-Brake-Lube-Brush/dp/B0015RCGRM
If it previously used a petroleum or other naturally organic based grease (like Sil-Glyde) rather than entirely silicone based, flush it out first.
Sil-Glyde is nothing special, there are a dozen I'd use before it but if that's what I had and there were no known incompatibilities, I wouldn't throw it away instead of using it.
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253020 10/29/19 11:37 AM
K
Online Content
K
The product's SDS does not list any polysiloxanes. Not that I wouldn't use it however, I have had good success with it on all of my cars (except the BMW which specifies no lubricant for the slide pins).
Edit - I will wind that back a bit. There seems to be conflicting information for the product. Some sources say it does not contain silicone yet others do. Is there more than one product?
1994 BMW 530i, 252K
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253027 10/29/19 11:44 AM
diyjake Online Content
Online Content
3M Silicone Paste holds up better and longer than Napa Sil Glyde.
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253029 10/29/19 11:46 AM
R
RamFan Offline
R
OP, is there a reason you're looking specifically at Silicone?
If not, you might want to consider CRC as an option. I've been using this for a few years and have no complaints and seems to work as described.
If you're only looking between these two, I'd go with 3M as you're getting more bang for your buck.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 24k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 68k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: Best Silicone Type for Caliper Pins [Re: painfx] #5253031 10/29/19 11:48 AM
Online Content
Critic - you said you wouldn't use neither, curious why not? You don't use anything at all or use something better?
Re: Best Silicone Type for Caliper Pins [Re: Dave9] #5253068 10/29/19 12:24 PM
B
BigD1 Offline
B
Yes that's very good lubricant. ACDelco brake lubricant with PTFE is the same lubricant, but it usually costs more than the Raybestos branded. Both are Fuchs Chemplex 839.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
Page 1 of 4 1 2 3 4
