In the general discussion section of another forum, (a firearms forum and not a car forum) there is a Kia tech that is quite active in such threads. I enjoy reading his very honest posts. He discusses the warranty issues at length. From reading his threads, there seems to be a continuing series of problems even with newer vehicles. All covered for newer vehicles.
The fact is, the problems are not limited to US built engines and not caused by debris, despite the numerous articles claiming such. Poor maintenance is absolutely a factor, as are the inherent design weaknesses. It's good to know that poor maintenance choices will shorten engine life with other brands too.
My suggestion is to choose a robust synthetic oil of higher viscosity and change it every 5000 miles. The fact is, these engine failures are closely related to a lack of viscosity, both due to thin oil choices and fuel dilution, coupled with particulate contamination.
We would like to think that manufacturers produce a robust product, capable of operating endlessly with the cheapest maintenance products possible (dealership fill for example) but that's simply not the case. The reasons are self evident for those willing to look, and include inexpensive components manufactured in exactly the same manner they have been for the last 50 years, yet with lower tension rings, smaller bearings, higher cylinder pressures and RPM, long timing chains that operate position critical variable cam timing devices, contaminate producing direct injection and the move to water thin oils. Do you really expect a different result?
